Engine specs on the old Mopar 360/380 hp magnum. #1859975
06/29/15 09:47 PM
06/29/15 09:47 PM
kentucky
roadrunner7020 Offline OP
kentucky
Does anyone have the engine specs on the old crate motors. Picked up a used one that a guy spun a bearing in. Before I go to far with it does anyone know the cam specs and what the cylinder bore is? The motor doesn't have any ring grove and it appears to just need the crank polished so far.
Re: Engine specs on the old Mopar 360/380 hp magnum. [Re: roadrunner7020] #1859989
06/29/15 09:55 PM
06/29/15 09:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
pretty much a stock long block Magnum with a bigger cam and single plane intake.
http://www.hotrod.com/how-to/engine/mopp-0303-360-crate-engine-buildup/
Don't be the exception.
Re: Engine specs on the old Mopar 360/380 hp magnum. [Re: roadrunner7020] #1860532
06/30/15 02:41 PM
06/30/15 02:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
.020 over coated Pistons, I'll get the specs on the cam, they're at home
Re: Engine specs on the old Mopar 360/380 hp magnum. [Re: cudaman1969] #1860537
06/30/15 02:54 PM
06/30/15 02:54 PM
dogdays Offline
dogdays  Offline
When the engines were being produced I understand they were just pulled from the production line. So bore would be 4.000" Later on, when the 5.9s weren't being produced, they used used blocks which required oversize pistons. Then when the $10,000 Mag crate motors came out they used replacement blocks and back to 4.000".
That's how I remember it.
R.
Re: Engine specs on the old Mopar 360/380 hp magnum. [Re: roadrunner7020] #1860560
06/30/15 03:17 PM
06/30/15 03:17 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Cam Info I have:
M.P. P4876348 (380 & 435 HP Crate Motor)
Advertised Dur. 288/292
Dur. @ .050 230/234
Lift(1.6) .501/.513
Center Line 108 deg.
Overlap 74 deg
Re: Engine specs on the old Mopar 360/380 hp magnum. [Re: Jwilli500] #1861184
07/01/15 12:36 PM
07/01/15 12:36 PM
kentucky
kentucky
thanks all
