Mopar Techs 04 Ram A/C question #1859814
06/29/15 06:07 PM
06/29/15 06:07 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Hey guys,
My 04 Ram A/C is cutting out at around 3000 rpm. What would cause that? Is there a relay I can replace?
Thanks!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Mopar Techs 04 Ram A/C question [Re: Dixie] #1859832
06/29/15 06:22 PM
06/29/15 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
By "cutting out" do you mean the airflow at the dash registers stops?
Don't know if the '04 still has vacuum motors that control the modes, but on earlier trucks the problem was loss of vacuum at heavy throttle...remedied by the addition of a vacuum check valve.
Re: Mopar Techs 04 Ram A/C question [Re: Dixie] #1859836
06/29/15 06:25 PM
06/29/15 06:25 PM
Dixie Offline OP
Dixie  Offline OP
The air stops blowing cold and blows warm at a lesser velocity.
Re: Mopar Techs 04 Ram A/C question [Re: Dixie] #1859842
06/29/15 06:30 PM
06/29/15 06:30 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I've got an 04 and they have a problem with the vent doors. You're loosing vacumm at higher RPM and the door is partially shutting allowing outside air to overwhelm the AC. Try it with cabin recirculation on, it may help. The vacuum check valve mentioned above may also help.
Re: Mopar Techs 04 Ram A/C question [Re: Cudajon] #1859893
06/29/15 07:53 PM
06/29/15 07:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a link to the TSB dealing with this problem on earlier trucks.
http://dodgeram.info/tsb/1996/24-01-96a.htm
Re: Mopar Techs 04 Ram A/C question [Re: Dixie] #1860292
06/30/15 10:24 AM
06/30/15 10:24 AM
Dixie Offline OP
Dixie  Offline OP
Thanks guys, it does it with recirc on, so maybe that check valve will help.
