'74 Power Wagon, NP205 XFer Case Shift Rod? #1859056
06/28/15 06:56 PM
06/28/15 06:56 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
The '74 Dodge Power Wagon I bought last November, has a NP435 Transmission and a NP205 Transfer Case.
While removing the transmission for overhaul, I noticed how crooked the Transfer Case Shift Linkage rod is and wondered if that was "normal" (as in intentionally bent as an adjustment from the factory) or if it was supposed to be Straight and was bent through years of service, etc?
So, Is it supposed to be Straight or bent/crooked?
Re: '74 Power Wagon, NP205 XFer Case Shift Rod? [Re: D_C] #1859129
06/28/15 08:47 PM
06/28/15 08:47 PM
Lehigh Acres, Florida
rickstershemi Offline
That looks like a homemade piece not factory...???
Rickster
Re: '74 Power Wagon, NP205 XFer Case Shift Rod? [Re: rickstershemi] #1859351
06/29/15 12:00 AM
06/29/15 12:00 AM
D_C Offline OP
D_C  Offline OP
Pretty sure it IS a factory part. I have seen a drawing of it in the Dodge Factory Service Manual, but the drawing does not show the entire shaft/part. The Factory Parts Manual would likely show it, but I don't have that manual.
I have seen photos of similar looking later-model shafts, but they are Straight and have an adjustable-length end piece that has a Set-screw.
Re: '74 Power Wagon, NP205 XFer Case Shift Rod? [Re: D_C] #1859723
06/29/15 04:12 PM
06/29/15 04:12 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The one on my 74 seems to be straight, well at least straight compared to yours.
Re: '74 Power Wagon, NP205 XFer Case Shift Rod? [Re: CTD5.9] #1860139
06/30/15 12:37 AM
06/30/15 12:37 AM
N
NITROUSN Offline
NITROUSN  Offline
N
iagree That rod is not right.
Re: '74 Power Wagon, NP205 XFer Case Shift Rod? [Re: NITROUSN] #1863291
07/04/15 03:29 AM
07/04/15 03:29 AM
D_C Offline OP
D_C  Offline OP
Thanks for the replies and Photo. I straightened mine today using a vice and an anvil.
