Early A trans crossmember #185943
01/06/09 07:46 PM
01/06/09 07:46 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
64 Dart 273/904. I am swapping in a 360/727. Is the trans crossmember the same for both transmissions?
Thanks,
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185944
01/06/09 07:48 PM
01/06/09 07:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yep. You will have to clearance the tunnel a little to get the 727 in though.
Re: Early A trans crossmember [Re: slantzilla] #185945
01/06/09 07:54 PM
01/06/09 07:54 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You'll also have to notch the passenger side of the crossmember for the exhaust to clear. This is the TTI modified crossmember.
Re: Early A trans crossmember [Re: dart4forte] #185946
01/06/09 08:58 PM
01/06/09 08:58 PM
there's a broad range of tolerances there, a few 727's will clear w no banging, most will clear with flattening or removing the pinchweld, a few need the tunnel hammered for clearance in addition to the pinchweld removed. BEST is to mock one up in your particular vehicle & see what you have, a person sure doesn't need to be hammering if they dont have to. Trim the crossmember on the one side w a whizzer to get it exact then remove it & weld some flat pieces across the gap you have created. 727 bolts in the same.
Re: Early A trans crossmember [Re: RapidRobert] #185947
01/07/09 02:17 PM
01/07/09 02:17 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
I thought I was going crazy. Put the trans in the other day (or I was trying to) and I couldn't get it all the way up with a poly bushing installed. This is the first ealy A body I have every played with and the seems to be little issues around every corner it seems.
Thanks,
Josh
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185948
01/07/09 02:43 PM
01/07/09 02:43 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
After disappointing results on my 273, I am seriously considering the 360 swap into my 1965 early A. I want to keep my cable operated 904 however. What oil pan did you have to use for your installation? Any other major problems?
Re: Early A trans crossmember [Re: rbstroker] #185949
01/07/09 03:29 PM
01/07/09 03:29 PM
center sump pass car 360 pan fits perfect. The aftermarket flex plate(I forget the #) takes care of the 360 to neutral balanced 904 issue. Add an ear to one of your 273 mts. I've use a 273 water pump on the 360 timing cover to keep my orig rad.
Re: Early A trans crossmember [Re: Jambbii] #185950
01/07/09 03:47 PM
01/07/09 03:47 PM
This is the first ealy A body I have every played with and the seems to be little issues around every corner it seems. Thanks,
Josh
Josh when you are done you'll be glad because they are sooo lightweight. Post your Q's. If you are going SB use a 904 especially since in your case you do not have enough tunnel clearance without modifying it & a 904 will hold up fine(just ask TBF )
Re: Early A trans crossmember [Re: RapidRobert] #185951
01/07/09 05:28 PM
01/07/09 05:28 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
I am actually building the car for a friend.
360 magnum, 11-1 comp. Eddy heads , big comp cam and I want to use the 727 because its already built ( my old one out of the challenger)
I am using a standard 360 car oil pan and it looks to clear fine with Schumacher poly engine mounts. The TTI headers make everything a huge pain in the butt to work on. I figured I could put the trans in with the headers on...Nope and then come to find out a 727 doesn't clear now
Does anyone have pics of the clearancing they have done to make these fit?
Josh
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: RapidRobert] #185952
01/07/09 05:30 PM
01/07/09 05:30 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
We had a custom radiator built, looks the same but out of aluminum!
Josh
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185953
01/07/09 05:45 PM
01/07/09 05:45 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
I put together a 65 dodge dart 2 door sedan.i myself wanted an a body but wanted something different.i put together 360 and 904. i could not imagine trying to put a 727 in the car as tight as a 904 is in there.i got the tti headers and the special starter and the starter did not fit.I used a regular mini starter on it.It is a close fit when it comes to some of the header tubes and i wish i had put fittings in the side of the block instead of using the 90 degree oil filter adapter and used a oil filter relocation kit.dartman366 did the fittings in the side of his block for a oil filter relocation kit. I did modifiey my cross member myself for the tti headers.Brad
Re: Early A trans crossmember [Re: roadrunnerreds] #185954
01/07/09 05:48 PM
01/07/09 05:48 PM
Gettysburg Pa
Gettysburg Pa
another pic
Re: Early A trans crossmember [Re: roadrunnerreds] #185955
01/07/09 05:50 PM
01/07/09 05:50 PM
Gettysburg Pa
Gettysburg Pa
pic 3
Re: Early A trans crossmember [Re: dart4forte] #185956
01/07/09 06:08 PM
01/07/09 06:08 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Something I forgot to mention is that if you use Schumacker polygraphite motor mounts you will raise the engine close to 1/8th of an inch. The poly bisquets do not settle or squish like the rubber. This will affect the headers collectors in that the bottoms of the collectors will be in line with the crossmember.
Re: Early A trans crossmember [Re: roadrunnerreds] #185957
01/07/09 06:14 PM
01/07/09 06:14 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Does this look like the right crossmember and mount?
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185958
01/07/09 06:15 PM
01/07/09 06:15 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
another
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185959
01/07/09 06:34 PM
01/07/09 06:34 PM
Wrong crossmember
Re: Early A trans crossmember [Re: RapidRobert] #185960
01/07/09 06:44 PM
01/07/09 06:44 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Wrong crossmember
I figured something was wrong! Anyone have pics of the right one and what does this look like it was out of/
Thanks,
Josh
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Early A trans crossmember [Re: Jambbii] #185961
01/07/09 07:07 PM
01/07/09 07:07 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Looks like an early "B" body to me.
This is the land of the free because of the brave
Re: Early A trans crossmember [Re: rbstroker] #185962
01/07/09 07:26 PM
01/07/09 07:26 PM
Gettysburg Pa
Gettysburg Pa
here is one that is not modified. Brad
