Re: 1970 Cuda will not start
[Re: jml19621]
#1859598
06/29/15 01:15 PM
06/29/15 01:15 PM
Posts: 4,811 Star Idaho
67vertman
Star Idaho
Are you sure the starter relay (the new one) is good? I had a brand new one that was bad.
also, check to make sure you ignition switch is working, set up a remote start, to see if you can eliminate that switch as a source of your non-crank issue.
My Monster are real!
Living within your means makes life pretty easy.
