Re: assembly lube
[Re: mopar dave]
#1859457
06/29/15 02:24 AM
06/29/15 02:24 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I use BG products on sides of pistons and all bearings. It looks like honey.
Mopar to the bone!!!
Re: assembly lube
[Re: madscientist]
#1859631
06/29/15 01:57 PM
06/29/15 01:57 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
Oil(the same oil that will be use in the motor) only on bearings,rings and pistons, rocxker shafts and any other part that gets lubricated from oil on it from the motor running ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Cam lube only on bottom of lifters and on cam lobes with non roller cams ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I do prelube the motors by priming the oil pump and spinning the motor on the starter before starting them also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: assembly lube
[Re: mopar dave]
#1859781
06/29/15 05:08 PM
06/29/15 05:08 PM
Thumperdart
State of confusion
Jason Pettis turned me on to Akerly&Childs assembly oil for piston skirts and rings and Torco MPZ for bearings and valve-train components and flat tappet cams..............
Re: assembly lube
[Re: mopar dave]
#1859820
06/29/15 06:09 PM
06/29/15 06:09 PM
Posts: 4,213 New York
polyspheric
New York
i'v been reading wd40 for piston rings, no oil.
X2 - motor oil may delay ring seating.
Boffin Emeritus
Re: assembly lube
[Re: Cab_Burge]
#1859830
06/29/15 06:19 PM
06/29/15 06:19 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Oil(the same oil that will be use in the motor) only on bearings,rings and pistons, rocxker shafts and any other part that gets lubricated from oil on it from the motor running ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Cam lube only on bottom of lifters and on cam lobes with non roller cams ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I do prelube the motors by priming the oil pump and spinning the motor on the starter before starting them also This is exactly how I do it also. I would add that the cam lube I use is whatever the cam company sends with it and if they don't send any I use STP on the foot.
