assembly lube #1859435
06/29/15 01:40 AM
06/29/15 01:40 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
what do you guys use for assembly lube. i'v used red line and royal purple in the past. whats the best stuff out there?
Re: assembly lube [Re: mopar dave] #1859442
06/29/15 01:56 AM
06/29/15 01:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use lubriplate 105 assembly lube on all the bearings, cam assembly lube on all the cam lobes and lifter (flat) faces and motor oil on the lifter bodies.
Re: assembly lube [Re: mopar dave] #1859457
06/29/15 02:24 AM
06/29/15 02:24 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I use BG products on sides of pistons and all bearings. It looks like honey.
Mopar to the bone!!!
Re: assembly lube [Re: mopar dave] #1859476
06/29/15 04:36 AM
06/29/15 04:36 AM
Washington
skrews Offline
skrews  Offline
Washington
Joe Gibbs assembly lube on bearings and cam, break-in oil on pistons and rings. Plenty of good products out there, hard to go wrong with any of them.
Re: assembly lube [Re: mopar dave] #1859487
06/29/15 07:45 AM
06/29/15 07:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
each to their own but i've been using the same Royal Purple as you have. nothing wrong with that oil.
Re: assembly lube [Re: mopar dave] #1859567
06/29/15 12:27 PM
06/29/15 12:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
STP
Re: assembly lube [Re: mopar dave] #1859575
06/29/15 12:37 PM
06/29/15 12:37 PM
Mt Morris Michigan
Mt Morris Michigan
the red line is a paste and I really didn't care for it. I prefer a oil like the royal purple which I did like. i'v been reading wd40 for piston rings, no oil.
Re: assembly lube [Re: mopar dave] #1859582
06/29/15 12:43 PM
06/29/15 12:43 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm using joe gibbs driven assembly lube this time around. It's a medium thick grease will stick where you put it. Summit has it cheap.
Re: assembly lube [Re: Exit1965] #1859591
06/29/15 01:00 PM
06/29/15 01:00 PM
Mt Morris Michigan
Mt Morris Michigan
i plan on using the joe gibbs breakin oil on the dyno. i'll take a look at that.
Re: assembly lube [Re: mopar dave] #1859599
06/29/15 01:18 PM
06/29/15 01:18 PM
Washington
madscientist Offline
Washington
Torco.
Re: assembly lube [Re: madscientist] #1859631
06/29/15 01:57 PM
06/29/15 01:57 PM
Oil(the same oil that will be use in the motor) only on bearings,rings and pistons, rocxker shafts and any other part that gets lubricated from oil on it from the motor running up Cam lube only on bottom of lifters and on cam lobes with non roller cams up I do prelube the motors by priming the oil pump and spinning the motor on the starter before starting them also up
Re: assembly lube [Re: Cab_Burge] #1859764
06/29/15 04:45 PM
06/29/15 04:45 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Clevite bearing guard on most stuff like bearings, engine oil on the rest.
Brian
Re: assembly lube [Re: mopar dave] #1859781
06/29/15 05:08 PM
06/29/15 05:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Jason Pettis turned me on to Akerly&Childs assembly oil for piston skirts and rings and Torco MPZ for bearings and valve-train components and flat tappet cams..............
Re: assembly lube [Re: mopar dave] #1859820
06/29/15 06:09 PM
06/29/15 06:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - motor oil may delay ring seating.
Boffin Emeritus
Re: assembly lube [Re: Cab_Burge] #1859830
06/29/15 06:19 PM
06/29/15 06:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
This is exactly how I do it also. I would add that the cam lube I use is whatever the cam company sends with it and if they don't send any I use STP on the foot.
Re: assembly lube [Re: mopar dave] #1859834
06/29/15 06:23 PM
06/29/15 06:23 PM
Mt Morris Michigan
Mt Morris Michigan
i'v heard of some using harley davidson straight 60 too. engine will be primed before start up.
Re: assembly lube [Re: mopar dave] #1859835
06/29/15 06:24 PM
06/29/15 06:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've used different stuff in the past, but my 452 bottom end went together with:
- Joe Gibbs assembly lube on crank & rod bearings and piston pins
- CMD assembly lube on rod bolts
- Total Seal AL4 piston & ring lube, plus their QuickSeat powder on the cylinder walls
Time will tell...
Re: assembly lube [Re: mopar dave] #1859843
06/29/15 06:30 PM
06/29/15 06:30 PM
P
Porter67 Offline
Porter67  Offline
P
WD40 on rings, std. oil on the bearings and high pressure red grease on the solid cams while checking and final lash-pre run, then cam lube.
Re: assembly lube [Re: mopar dave] #1861021
07/01/15 01:37 AM
07/01/15 01:37 AM
Mt Morris Michigan
Mt Morris Michigan
i ordered the joe gibbs assembly lube for something like $4. since i will be using their break in oil. thanks
Re: assembly lube [Re: mopar dave] #1861044
07/01/15 04:04 AM
07/01/15 04:04 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Torco
Never had any problem
EVER!
