Early A trans crossmember
#185943
01/06/09 07:46 PM
01/06/09 07:46 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
64 Dart 273/904. I am swapping in a 360/727. Is the trans crossmember the same for both transmissions?
Thanks,
Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
Re: Early A trans crossmember
[Re: slantzilla]
#185945
01/06/09 07:54 PM
01/06/09 07:54 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Yep. You will have to clearance the tunnel a little to get the 727 in though.
You'll also have to notch the passenger side of the crossmember for the exhaust to clear. This is the TTI modified crossmember.
[Re: dart4forte]
#185946
01/06/09 08:58 PM
01/06/09 08:58 PM
RapidRobert
there's a broad range of tolerances there, a few 727's will clear w no banging, most will clear with flattening or removing the pinchweld, a few need the tunnel hammered for clearance in addition to the pinchweld removed. BEST is to mock one up in your particular vehicle & see what you have, a person sure doesn't need to be hammering if they dont have to. Trim the crossmember on the one side w a whizzer to get it exact then remove it & weld some flat pieces across the gap you have created. 727 bolts in the same.
[Re: RapidRobert]
#185947
01/07/09 02:17 PM
01/07/09 02:17 PM
Jambbii
Mesa , Az
I thought I was going crazy. Put the trans in the other day (or I was trying to) and I couldn't get it all the way up with a poly bushing installed. This is the first ealy A body I have every played with and the seems to be little issues around every corner it seems.
Thanks,
Josh
[Re: RapidRobert]
#185951
01/07/09 05:28 PM
01/07/09 05:28 PM
Jambbii
Mesa , Az
I am actually building the car for a friend. 360 magnum, 11-1 comp. Eddy heads , big comp cam and I want to use the 727 because its already built ( my old one out of the challenger) I am using a standard 360 car oil pan and it looks to clear fine with Schumacher poly engine mounts. The TTI headers make everything a huge pain in the butt to work on. I figured I could put the trans in with the headers on...Nope and then come to find out a 727 doesn't clear now Does anyone have pics of the clearancing they have done to make these fit? Josh
[Re: dart4forte]
#185956
01/07/09 06:08 PM
01/07/09 06:08 PM
dart4forte
Mesa, Arizona
Something I forgot to mention is that if you use Schumacker polygraphite motor mounts you will raise the engine close to 1/8th of an inch. The poly bisquets do not settle or squish like the rubber. This will affect the headers collectors in that the bottoms of the collectors will be in line with the crossmember.
[Re: roadrunnerreds]
#185957
01/07/09 06:14 PM
01/07/09 06:14 PM
Jambbii
Mesa , Az
Does this look like the right crossmember and mount?
[Re: Jambbii]
#185961
01/07/09 07:07 PM
01/07/09 07:07 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Looks like an early "B" body to me.
This is the land of the free
because of the brave
