520" Stroker finally ready for the dyno
#1856805
06/25/15 05:37 PM
06/25/15 05:37 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
This has been almost two years in the making, but here we go. Dyno time scheduled for tonight !
Its a 440 based 520" stroker using a stock '68 440 block. +.030 4.375 Stroker kit is from 440 source w/30cc dished pistons. Heads are Indy EZ 295 CNC's finish prepped by Dwayne Porter, compression 10.5-1, cam is a Bullet Hydraulic Roller 252/258 @ .050, .622 lift with 1.6 Crane rockers, 110lsa, Indy Dual plane opened up to max wedge ports, Single line external oiling. 1000cfm Quick Fuel 4150.
This engine was originally intended to be used in a 1970 Super Bee with all steel and full interior, and everything that came from the factory including no cage, but that car is sold. I'm back to owning my old 65 Coronet wagon with a great running healthy 470, so I'm not even sure what I'm going to do with this engine at this point...
I will be sure to update (hopefully tomorrow)with dyno numbers and a pic or two. I'm not going to do any guesssing on HP. This dyno is un-happy, so I won't be expecting any magazine numbers, but I would be disappointed if it didn't crack the 600 mark.
Care to share your guesses??
2 kids and a dog
Re: 520" Stroker finally ready for the dyno
[Re: TonyS451]
#1856816
06/25/15 05:57 PM
06/25/15 05:57 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Best of luck and I am sure you will see your goal..
[Re: TonyS451]
#1857173
06/26/15 12:23 AM
06/26/15 12:23 AM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Congrats Tony Everything you are ever involved in is top shelf. Good luck with the motor.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: PJ68RT]
#1857310
06/26/15 11:10 AM
06/26/15 11:10 AM
TonyS451
Chicago, IL
Thank for all the support guys. The dyno session went well and most importantly, nothing went wrong! The engine produced decent power and I do not feel disappointed at all. I knew I was leaving power on the table, but I feel for a Real street car, this engine will be perfect.
Peak HP - 655 @ 6000 (659 w a 1" 4 hole spacer) Peak TQ - 618 $ 4700 (596 @ 3500)
Pics to follow
2 kids and a dog
[Re: TonyS451]
#1857328
06/26/15 11:41 AM
06/26/15 11:41 AM
Posts: 4,687 Wichita
GY3
Wichita
Pics to follow Awesome! Beast of a motor for a street car. I wasn't too far off...
[Re: TonyS451]
#1857344
06/26/15 12:28 PM
06/26/15 12:28 PM
Thumperdart
State of confusion
Pics to follow Nice numbers...............what`s a real street car?
[Re: Thumperdart]
#1857501
06/26/15 05:21 PM
06/26/15 05:21 PM
TonyS451
Chicago, IL
Pics to follow Nice numbers...............what`s a real street car? Obviously an often debated topic, so I should have known better than to make that comment without an asterisk next to it. To ME, a real street car is a car that doesn't require climbing into a jungle gym, one that can jump onto the freeway at any time and cruise 50 miles without hesitation, nice idle, pump gas, doesn't need maintenance after ever drive, has most factory equipment still intact, full exhaust, street tires, tagged and drives to the track if raced. I think this engine would do well in a car like I described.
2 kids and a dog
[Re: TonyS451]
#1857533
06/26/15 06:02 PM
06/26/15 06:02 PM
Thumperdart
State of confusion
Pics to follow Nice numbers...............what`s a real street car? Obviously an often debated topic, so I should have known better than to make that comment without an asterisk next to it. To ME, a real street car is a car that doesn't require climbing into a jungle gym, one that can jump onto the freeway at any time and cruise 50 miles without hesitation, nice idle, pump gas, doesn't need maintenance after ever drive, has most factory equipment still intact, full exhaust, street tires, tagged and drives to the track if raced. I think this engine would do well in a car like I described. Wasn`t looking to argue just curious about your version and I agree, just climbing over by door bar can be fun but that`s what I personally love................noise, burnt rubber and loud as hell............... Enjoy, and nice numbers......
[Re: AndyF]
#1857673
06/26/15 08:45 PM
06/26/15 08:45 PM
dogdays
I just looked at the torque curve...high and flat. Wow. Max numbers are cool, but put that engine in a car that hooks up, floor it and the engine just won't stop pulling until you get off the throttle.
If the heads are good enough, large duration cams aren't needed to crutch the airflow.
Andy's right, that engine needs a lot more carb. There's a lot more power hiding in that engine.
R.
