Low/No cost 727 mods #1856565
06/25/15 01:01 PM
06/25/15 01:01 PM
Canada
WO23Coronet Offline OP
Canada
I'm about to do a fluid/filter change on my Coronet, and was thinking while I have my pan off if there's any mods I can do to improve shifting. I'm not interested in a shift kit at this time, cause I might pull the tranny next year for a torque converter swap and add one then. Anything I can do while I've got the pan off?
Re: Low/No cost 727 mods [Re: WO23Coronet] #1856618
06/25/15 01:46 PM
06/25/15 01:46 PM
as you know you'd wanna adj the inside band while you are there. I'd say bumping the line psi with the screw/bracket on the side of the VB. Not sure how much/far
Re: Low/No cost 727 mods [Re: RapidRobert] #1856634
06/25/15 02:03 PM
06/25/15 02:03 PM
Canada
Canada
Yeah I'm going to adjust the bands while I'm there (72 in-lbs, back off 2 1/4 turns)
Re: Low/No cost 727 mods [Re: WO23Coronet] #1856639
06/25/15 02:07 PM
06/25/15 02:07 PM
I never could get to 72 in lbs (might have been a torque wrench prob) so I ended up adj the bands per Kunkels advice to 1/4 and 5/16 (iirc)
Re: Low/No cost 727 mods [Re: WO23Coronet] #1857084
06/25/15 10:52 PM
06/25/15 10:52 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
ATF+4
Re: Low/No cost 727 mods [Re: DartGTX] #1857576
06/26/15 06:57 PM
06/26/15 06:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By DartGTX
ATF+4
To improve shifting? Only if you consider a Dynaflow an "improvement". confused
Re: Low/No cost 727 mods [Re: John_Kunkel] #1857772
06/26/15 11:23 PM
06/26/15 11:23 PM
GEORGIA
barracuda7199 Offline
GEORGIA
Accumulator blocking rod. You could upgrade the servos relatively easily.
Re: Low/No cost 727 mods [Re: WO23Coronet] #1858300
06/27/15 06:11 PM
06/27/15 06:11 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
I would replace the shifter seal while I was in there, but that's just me.
Re: Low/No cost 727 mods [Re: WO23Coronet] #1858674
06/28/15 02:38 AM
06/28/15 02:38 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Not sure who told me but it was on this forum. The 72 inch/pounds while being a standard measurement, isn't as critical as the books make it sound. The trick I remember reading was, tighten the band "snug but not tight". If it feels like you are flexing parts, you are. 72 inch/pounds really isn't that tight. Then back off the prescribed number of turns. That's the important part. DO NOT FORGET THIS!! damhik You find out real fast whistling
Scott
Re: Low/No cost 727 mods [Re: Scott Carl] #1858726
06/28/15 10:13 AM
06/28/15 10:13 AM
moparx Offline
moparx  Offline
the august 2000 issue of mopar action mag had an article on no cost tips by member ehrenburg. it probably is on their web site. if you can't find it, pm me with your e-mail addy, and i'll send you a copy.
beer
Re: Low/No cost 727 mods [Re: moparx] #1858749
06/28/15 11:07 AM
06/28/15 11:07 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
beer
It came from the old 80's Direct Connection racing manual and they work,also includes a few changes in the valve body.
Re: Low/No cost 727 mods [Re: WO23Coronet] #1859104
06/28/15 08:19 PM
06/28/15 08:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I give the bands 1/8th inch play on the front and about 1/4 play on the rear.
Blocking the acumulator makes 1-2 harder but not 2-3 so it feels weird with one hard shift and one soft one.
I do crank the line pressure screw up till the tip is flush with the moving piece, it don't move it but a few pounds and typically no more than getting it in spec since the spring loses tension after 40 years or so.
