Re: 11 durango whacky dash
[Re: sogtx]
#1856144
06/24/15 07:34 PM
06/24/15 07:34 PM
Posts: 5,188 upstate western ny
sogtx
upstate western ny
Pic taken with engine idling ..
obvious answer - take to service dealer
Trade in to dealer ? Only 5o k miles
Pull battery / reset ?
I should start a poll :))
[Re: Alaskan_TA]
#1856172
06/24/15 08:36 PM
06/24/15 08:36 PM
sogtx
upstate western ny
Ive tried different key . Same deal happened two weeks ago , I figured maybe somemthing was moist with all the rain everyones getting.
But it came back - i know that i can clear it with Pullin battery, or i assume. But there's an underlying issue , has to be. Barry If its as dumb as an abs sensor, Ill buy you some beers at Calisle ... I just noticed i have a chewed up rear rotor Are there brake sensors on these ? I guess i gotta pop it on the lift ..
[Re: sogtx]
#1856439
06/25/15 07:15 AM
06/25/15 07:15 AM
Posts: 286 Catskill, NY
teflon
Catskill, NY
There are no brake pad sensors. It appears that the vehicle is loosing bus communication or could be cluster itself. You would want to check for codes, my guess is your going to have a lot of lost communication codes.
[Re: sogtx]
#1857041
06/25/15 09:00 PM
06/25/15 09:00 PM
sogtx
upstate western ny
Thanks for all the replies - Did replace the rear rotors and pads last nite, i Thought that mercedes would have implemented the pad sensors, but not. I did pull and clean batt terminals. Of course all worked well after. I hocked a scan tool from the garage next door to my office , no codes. Go figure. Im pretty sure its just the ol' ladies negtive energy.
