Can a 318 fit in a chevy van engine compartment #1855216
06/23/15 02:59 PM
06/23/15 02:59 PM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
I have a cube van chassis with a bad 350 in it. Since I have 2 good engines/transmissions (318/360) and can fabricate, would a mopar physically fit in the space using a motor plate setup? The 360 is completely rebuilt, and a used 350 or another engine build is not an option.
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1855238
06/23/15 03:21 PM
06/23/15 03:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There is no good reason it won't fit. The engines are very similar in size.
Be sure the oil pan won't interfere.
- Stu Harmon
Re: Can a 318 fit in a chevy van engine compartment [Re: feets] #1855267
06/23/15 03:53 PM
06/23/15 03:53 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Depending on which (318-360) you decide to use you may have to use a truck pan and pick-up as Feets hinted to. Dimensionally check the design of the existing pan and compare them. twocents
As for the motor mounts, driveshaft and exhaust since you can fab you should be able to make something there work.
I'd say if its an older model without a lot of electronics it shouldn't be a big deal...
SBC's are everywhere for not a lot of money...I'm not sure a swap is the most fiscal approach...shruggy
...FAFO...
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1855378
06/23/15 06:22 PM
06/23/15 06:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I agree find someone to swap the 360 for a chevy motor.
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1855888
06/24/15 01:34 PM
06/24/15 01:34 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
laugh2 up
You da Man!!!!!
Best post I've seen in a while. Please update with photos so I can rub it in gm fanatics' faces. beer
Mo' Farts
Moderated by "tbagger".
Re: Can a 318 fit in a chevy van engine compartment [Re: Grizzly] #1856062
06/24/15 06:05 PM
06/24/15 06:05 PM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
Actually both mopars are in vans so the oil pan issue should be ok. After gm guys tell you the engine comes out the door, etc. well that's WHY I ASK MOPAR people. OK, its a steel bus body that's why I wanted it. For fun I go look up the ProMod Camaros w/chry.440 for the engine... anybody really think those engines are ford, toyota or gm in their favorite funny car? Over N out!
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856245
06/24/15 10:58 PM
06/24/15 10:58 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I did an engine swap in a 74 B100 several years ago. IIRC, it had to come out the passenger door. I don't know about Chevy vans, but again IIRC, the radiator support is welded in. Even if its bolted in, it was easier coming out the door than removing the front of the van. YMMV smile
Scott
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856308
06/25/15 12:14 AM
06/25/15 12:14 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Sorry if I was one of the 5 that offended you, I will pass by your postings in the future whistling
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856384
06/25/15 02:07 AM
06/25/15 02:07 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Size for the GM 350 and the Mopar 360 are about the same. Weight is about the same. The biggest issue will be the Mopar starter location. GM has the starter on the passenger side, Mopar is on the driver side. Usually, the driver side is pretty congested. If there is room for the starter, and you don't mind the hassle the Drive shaft will present, I'd go for it.
Years ago I put a 318 in a mid 60s Chevy truck because the guy kept blowing up 350s. I told him I had a motor that would outlast the truck if he kept oil in it and didn't overheat it. He pounded on that 318 and did everything he could think of, but the truck gave up before the 318.
The 318 in the mid 70s Pontiac was a bit of a challenge, and the 318 in an 82 Jeep J10 was another challenge. Gene
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856400
06/25/15 02:51 AM
06/25/15 02:51 AM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
Hey all of you lookers, this is what I'm TALKIN ABOUT. I get 5 people for every one that actually KNOWS ANYTHING. And eventually, somebody has done this that's what I am really trying to find out...Im just trying to get a bit of information from any body that is the same situation, I could shred any body that has the time about mopar vs. whatever. I guess the ShermanTank was not a mopar? How about the turbine tank oh, yea the GM prototype could not get out of reverse during the trials at the GM Tech Center? I live two blocks from there. And I remember. The GM tank sucked and any body that say mopar sucks need to hit the library. Over N Out !
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856404
06/25/15 03:01 AM
06/25/15 03:01 AM
dogdays Offline
dogdays  Offline
They're very close in size. If you have the equipment, and as time is free, you can make it work. I believe stock exhaust manifolds will be okay as well.
From where I'm standing, starter position could be helped when you custom fabricate the engine mounts. I'd be most worried about linkage to the transmission if I were doing it and using an automatic. Also there will probably be some universal joint tomtrickery needed.
Good Luck,
R.
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856410
06/25/15 03:25 AM
06/25/15 03:25 AM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
Yes, I agree the starter and a couple other things, it has a HydroBoost is what they callled it, lines to the brake booster AND steering, THANKS GENEROUS MOTORS... and to everybody that had to bite their tongue I really appreciate it. Anyone catch the fact I fabricate...way back on the original post...Over N Out.
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856465
06/25/15 10:05 AM
06/25/15 10:05 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There was an Astro van that came to the Mopar Nats years ago that had a 360 in it. The guy said it was almost a bolt-in! eek
JB Rhinehart, Realist
A-Body's RULE!
Re: Can a 318 fit in a chevy van engine compartment [Re: TJP] #1856600
06/25/15 01:27 PM
06/25/15 01:27 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Kinda like a kick in the sack aint it... runaway
...FAFO...
Re: Can a 318 fit in a chevy van engine compartment [Re: MagnumGT] #1856607
06/25/15 01:31 PM
06/25/15 01:31 PM
dogdays Offline
dogdays  Offline
Actually I love the Hydroboost. All it needs is a pressure line to the power steering pump (Y'd into the pressure line) and a return line to the power steering reservoir. Your truck already has the hoses, you just need to attach to the Mopar pump, which may very well have been made by Saginaw.
R.
Re: Can a 318 fit in a chevy van engine compartment [Re: skicker] #1856785
06/25/15 05:11 PM
06/25/15 05:11 PM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
Not offended, just that after 3 mopar engine swaps, all out the front, I know how it was done. Yes the chevy core support is welded in place and it looks like less room than a Dodge. When someone tells me it comes out the door on van I just figure they mean a chevy van or the old B100 type which is correct. Great info and I'll have to just see how it goes... Thanks to all.
