Re: 440 timing chain hitting timing cover
[Re: CoDart]
#1856262
06/24/15 11:18 PM
06/24/15 11:18 PM
Posts: 31,050 Oregon
AndyF
[Re: CoDart]
#1856289
06/24/15 11:52 PM
06/24/15 11:52 PM
RapidRobert
Hello Ori, it's been awhile. the simple ans would be is the cover too shallow (what Andy said mockup an OE one) OR is the cam protruding more than an OE cam setup (I wouldnt think so otherwise you'd need a custom cover designed for roller cam if there is such an animal). never heard of one but I've never considered a roller setup so I ain't never researched what is needed for that. Holler how it turnes out. Is the cam seated rearward where it is supposed to be?
[Re: CoDart]
#1856367
06/25/15 01:40 AM
06/25/15 01:40 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Look like pretty tall socket heads, can you find alternative fasteners or maybe grind enough off the bolt face to get relief?
That little shouldn't compromise it's strength??
Joe
Edit..looks like the cam button sticks out further than the bolts or is it the angle of the photo??
[Re: CoDart]
#1856977
06/25/15 08:52 PM
06/25/15 08:52 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I just went through this with my 440 but used a stock cover.
I wish I measured the amount I took off the cam button but I didn't. I can tell you I took off quite a bit. I then made a washer and ground it on a surface grinder to make it the correct thickness for 0.007 to 0.010 inches clearance. I missed and had to add a 0.005 inch shim.
As you can see I used button head allen bolts.
[Re: CoDart]
#1859311
06/28/15 11:19 PM
06/28/15 11:19 PM
Posts: 318 Fort Collins, Colorado
CoDart
Good news! I got it all together. After working on small blocks all My life, this is the first big block I've done and I have learned a lot along the way. To fix that issue I first posted, I cut down the heads on the allen bolts and then made the button have 0.010" clearance. We are golden! Just a FYI, that timing cover was the eBay Mopar big block fabricated one. I would never get one again. The front seal diameter was 0.020" small and was not square all the way around the circle. We had to get a honing bar and hone it so the seal would 0.004" press on it instead of pressing it into a impossible 0.020" smaller diameter.
