If you change from an 8¼" to an 8¾" rearend in a '69 Charger #1854988
06/23/15 05:42 AM
06/23/15 05:42 AM
Maine
MaximRecoil Offline OP
Maine
Do you need a different length driveshaft?
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855041
06/23/15 10:23 AM
06/23/15 10:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855198
06/23/15 02:43 PM
06/23/15 02:43 PM
I would do the change and see if you can have your driveshaft shoten locally work I'm almost sure that the 8 3/4 pinion yoke sticks out further, its longer, than the 8 1/4 does scope Let us know what you do up BTW, you may have a 7 1/4 instead of the 8 1/4 scope
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855218
06/23/15 03:03 PM
06/23/15 03:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Dimensions.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: John_Kunkel] #1855274
06/23/15 04:08 PM
06/23/15 04:08 PM
find the correct donor shaft for your rear axle & if you have one cut mockup so you can get an exact/correct C to C number (I like 5/8-3/4" end play) loaded/level. Wouldn't hurt to check the end play of a donor shaft during installation also
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855284
06/23/15 04:21 PM
06/23/15 04:21 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
According to the chart it's about 5.8" too long.
The factory yoke to seal clearance is WAY too generous in every application I've seen. There is often more than 1.5" of clearance and 3/4" is plenty for a leaf sprung car.
I'd recommend installing the old driveshaft and checking yoke to seal clearance before you cut anything. If there is 3/4" or more, it will be fine. As long as it doesn't bottom out, the more spline engagement, the better.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: Magnum] #1855309
06/23/15 04:54 PM
06/23/15 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You mean 5/8" right? grin
If there is no dust boot on the transmission you could probably get away with the shaft you now have.
If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: Magnum] #1855310
06/23/15 04:54 PM
06/23/15 04:54 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
According to the chart it's about 5/8" too long.
Fixed... laugh2
Edited for getting TREED!!!!!!! fan realmad biggrin
...FAFO...
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855368
06/23/15 06:12 PM
06/23/15 06:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I thought the 8-1/4 didn't come out till late 70 early 71. Don't remember ever seeing a Charger-Coronet with anything but an 8-3/4 in 69. I changed out quite a few carrier bearings after that time from defects in the 8-1/4. In fact I can't remember seeing any in the 71-72 Charger just the 4-door Coronets. 1973 up, a-b-c base models 8-1/4, e-body 8-3/4. Could be wrong been awhile.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: Cab_Burge] #1855383
06/23/15 06:35 PM
06/23/15 06:35 PM
Maine
Maine
It is definitely an 8¼" rearend.
Unfortunately, a lot of 318 '69 Chargers came with a 904 transmission and an 8¼" rearend like mine did, rather than a 727 and 8¾". The changeover seems to have happened at some point during the 1969 model year. I asked about this a couple of years ago on another forum:
http://www.dodgecharger.com/forum/index.php?topic=104494.0
Thanks for the chart. I assumed there would be some difference in length; I just didn't know if it would be enough to matter.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: cudaman1969] #1855464
06/23/15 08:14 PM
06/23/15 08:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I had several 318 69 chargers with the 8 1/4 axle.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855473
06/23/15 08:23 PM
06/23/15 08:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 8 1/4" rear was a new addition for some 1969 model year cars.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1855475
06/23/15 08:27 PM
06/23/15 08:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
"Unfortunately, a lot of 318 '69 Chargers came with a 904 transmission and an 8¼" rearend like mine did, rather than a 727 and 8¾". The changeover seems to have happened at some point during the 1969 model year. I asked about this a couple of years ago on another forum:"
Well that's what I like about this forum, never too old to learn something new. What a bummer by the way, couldn't see Dodge doing that to a great car just to save a few bucks.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: Alaskan_TA] #1855476
06/23/15 08:33 PM
06/23/15 08:33 PM
Maine
Maine
That's right:
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: cudaman1969] #1855948
06/24/15 03:07 PM
06/24/15 03:07 PM
dogdays Offline
dogdays  Offline
If you save $5 on 100,000 cars it's a half-million. Every car manufacturer does the math.
R.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: dogdays] #1856001
06/24/15 04:12 PM
06/24/15 04:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
R.
They didn't sell 100,000 Chargers total but I know where you're coming from, dad worked at Fisher Body-Buick division in the 50s and said they would look for a haft cent to save.. In retrospect I don't think you could get the 904 with anything but the base rears. Upgrade the rear and this got the 727 I guess. Got two Dusters, one is 3 on the tree 6 cyl-7-1/4, other is synchronized 3 speed 6 cyl-8-3/4 so I'm thinking packages. Question for the group, where there any 318-904 mated to the 8-3/4 or just the 318-727 from 66-68 in the big cars- b&c bodys?
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: cudaman1969] #1856022
06/24/15 04:40 PM
06/24/15 04:40 PM
Maine
Maine
In the thread I linked to earlier, someone posted:
I have owned several 1968 and 1969 Chargers that were factory 318 cars. All had a 8 3/4 rear end and 904 transmission.
I don't know if he intended to type 8¾ instead of 8¼ or not.
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: cudaman1969] #1856066
06/24/15 06:12 PM
06/24/15 06:12 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Question for the group, were there any 318-904 mated to the 8-3/4 or just the 318-727 from 66-68 in the big cars- b&c bodys?
I sold a 68 Coronet 440 h/t a couple years ago that was 318-904-8 3/4... twocents
...FAFO...
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1856075
06/24/15 06:28 PM
06/24/15 06:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
My '70 Swinger also has 318, 904 & 8 3/4".
My '70 Coronet came with 318, 904 & 8 1/4".
Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger [Re: MaximRecoil] #1856391
06/25/15 02:28 AM
06/25/15 02:28 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks guys, just don't hear much about the standard engine-trans-rears
