Timing Question: 528 Hemi with aluminum Heads #185534
01/06/09 12:08 PM
01/06/09 12:08 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
What are you guys with an aluminum headed hemis running for timing. Mine is a 528, stage V aluminum heads with 2 Eddy 650 AVSs on the street. CR is roughly 10.4:1. Right now I have my MSD set at 17 initial with a total of 35 total. Seems to start OK with the 17 degrees of initial.
Re: Timing Question: 528 Hemi with aluminum Heads [Re: Hemi_Ram] #185535
01/06/09 01:58 PM
01/06/09 01:58 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
That should work really well. Usually 32-35 total worked well for my 472 (even with all of the problems I was having)
Re: Timing Question: 528 Hemi with aluminum Heads [Re: torkrules] #185536
01/06/09 02:34 PM
01/06/09 02:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
30 to 35 with good gas.
Re: Timing Question: 528 Hemi with aluminum Heads [Re: B G Racing] #185537
01/06/09 02:35 PM
01/06/09 02:35 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
37 with 110
Re: Timing Question: 528 Hemi with aluminum Heads [Re: prochargedhemi] #185538
01/06/09 02:50 PM
01/06/09 02:50 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Sounds good; thanks for your inputs..
