interior lights help #1855048
06/23/15 10:30 AM
06/23/15 10:30 AM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
None of my interior lights work. I have a 1970 gtx. Where and what should I be looking for to fix them.
Thank you,
Joe
Re: interior lights help [Re: joedee] #1855091
06/23/15 12:03 PM
06/23/15 12:03 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Start at the fuse box 3 amp fuse. Then pull the bulbs. Does the dome light work?
Re: interior lights help [Re: Pynzo] #1855102
06/23/15 12:22 PM
06/23/15 12:22 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
No, Dome light does not work.
Joe
Re: interior lights help [Re: joedee] #1855213
06/23/15 02:58 PM
06/23/15 02:58 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Ok that one is also fused at the box. How about brake lights? They're on the same circuit as the dome / map lights. If they work check the bulb and door switches. Dome light also grounds at the dimmer switch. Try spinning the wheel.
Re: interior lights help [Re: Pynzo] #1855278
06/23/15 04:10 PM
06/23/15 04:10 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Thank you for the info. I will check those items out. Did not know the brake lights were on the same circuit.
Joe
Re: interior lights help [Re: joedee] #1855301
06/23/15 04:46 PM
06/23/15 04:46 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
The Hazard Flasher is also on that circuit.
