Hemi solid lifters #185493
01/06/09 10:46 AM
01/06/09 10:46 AM
Eighty Four, PA
B G Racing Offline OP
Eighty Four, PA
Does anyone make a taller lifter(solid flat)That has the push rod cup location apoxamately .200 higher than stock or Comps?
Re: Hemi solid lifters [Re: B G Racing] #185494
01/06/09 10:57 AM
01/06/09 10:57 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
call crower in cally, the have one with different cup base. cant remember if its plus or minus .200
MOPAR OR NO CAR
Re: Hemi solid lifters [Re: B G Racing] #185495
01/06/09 12:11 PM
01/06/09 12:11 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Bob,
The Howards EDM lifters are taller as they are actually AMC.
Here is a picture by 440 Jim i think.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi solid lifters [Re: Hemi Allstate] #185496
01/06/09 12:33 PM
01/06/09 12:33 PM
Eighty Four, PA
Eighty Four, PA
Thanks guys,at least I have some where to start.I feel the problem is at base circle of the cam.I'am waiting for some cam measurements to confirm.
Re: Hemi solid lifters [Re: B G Racing] #185497
01/06/09 01:21 PM
01/06/09 01:21 PM
I have a set of the new Comp AMC roller lifters for one of my next projects, the cups are quiet a bit higher than the Comp Mopars, maybe you should have them send you one to try on the problem motor Is the exhaust pushrods rubbing hard on a aluminum block?
Re: Hemi solid lifters [Re: Cab_Burge] #185498
01/06/09 01:39 PM
01/06/09 01:39 PM
Eighty Four, PA
Eighty Four, PA
Thanks Cab and everyone for the help.Sam at Indy has a cam with the correct base circle and AMC lifters on the way.Moparts is great,thanks again all.
