Re: Where can I find a rad hose spring (separate)
[Re: wally426ci]
#1854437
06/22/15 04:54 PM
06/22/15 04:54 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Maybe you can find a used spring at an auto repair shop trash can or Pick A Part junkyard?
Ideally, you buy a new hose, if the old spring rotted away, the hose is probably soft or cracked inside and should be replaced. Hoses can look Ok on the outside, but be nearing failure on the inside.
That said, I removed the spring from a lower hose on my '74 W200 while servicing the system, de-rusted the spring, cleaned, primered, and painted the used spring before I reinstalled it in the used hose.
[Re: wally426ci]
#1854461
06/22/15 05:16 PM
06/22/15 05:16 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Make your own. Wind some 1/16" stainless steel tig welding rod around the appropriate sized pipe.
[Re: thehemikid]
#1854535
06/22/15 06:46 PM
06/22/15 06:46 PM
RapidRobert
as said go to a welding shop & get a piece of something stainless. Form it around a broom handle to shape it then turn the ends inward toward the center so they will never contact the hose wall
[Re: wally426ci]
#1854713
06/22/15 09:16 PM
06/22/15 09:16 PM
Challenger 1
Cincinnati, Ohio
Why not wrap any wire around a broom stick, it don't have to be stainless. Sure stainless sounds good but it don't have to be. I have used coat hanger wire from my work uniforms at least twice that I can think of. If the anti freeze is maintained then the steel will outlast the rubber hose.
Why spend any time going to a junk yard or any money on buying anything. Any wire will work, I've done it like 6 times in my life. '
[Re: Challenger 1]
#1855228
06/23/15 03:13 PM
06/23/15 03:13 PM
John_Kunkel
Rio Linda, CA
I would think a broomstick is too small; if the spring is too small in diameter it can be sucked into the water pump housing. The spring should fit the ID of the hose snuggly.
[Re: wally426ci]
#1855231
06/23/15 03:16 PM
06/23/15 03:16 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I bent a piece of coat hanger around a steel bar and shoved it in the hose.
Problem solved.
Antifreeze contains rust inhibitor so I didn't worry about that.
[Re: wally426ci]
#1855386
06/23/15 06:41 PM
06/23/15 06:41 PM
Posts: 4,273 Morrow, OH
markz528
Morrow, OH
I bought SS spring wire and did the broom handle trick. Worked great.
[Re: BDW]
#1855459
06/23/15 08:04 PM
06/23/15 08:04 PM
Challenger 1
Cincinnati, Ohio
I want to save a buck as much as anyone, but why run around searching for the right wire (or cutting coat hangers) and winding it the right diameter, when you can have a SS Spring delivered to your mailbox for $6. Only because I want to get my projects done, right away and am too impatient to wait on a silly part like that. It's not the money it's the time.
[Re: wally426ci]
#1855466
06/23/15 08:15 PM
06/23/15 08:15 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I made one for a friend...went to home depot and bought a 48" Brass rod...malleable..I curled it around a stainless 1" pipe that I use to extend my breaker bar .... rolled it into the pipe....works great.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: John_Kunkel]
#1855860
06/24/15 01:01 PM
06/24/15 01:01 PM
RapidRobert
I definitely agree & the last one I did I forgot what material it was but after forming it around the broom handle then when removed it it sprung back to where it was (now) a snug fit when I coiled it into the hose
[Re: RapidRobert]
#1856130
06/24/15 07:58 PM
06/24/15 07:58 PM
markz528
Morrow, OH
I definitely agree & the last one I did I forgot what material it was but after forming it around the broom handle then when removed it it sprung back to where it was (now) a snug fit when I coiled it into the hose Broomstick is correct if you use spring wire........
