Re: Small Block Stroker Oil Pan Question
[Re: dmerc]
#185426
01/06/09 09:58 AM
01/06/09 09:58 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Stock pan will work. I use the Kevko 6 quart M301. Since it has a built in crank scraper and baffles no need for a windage tray. Fits an a-body with TTI headers without issues: http://www.kevko.net/mopar.htmI am running Scat I-beams and block did not have to be clearanced with the 4" stroke.
[Re: DropTopE]
#185429
01/06/09 12:30 PM
01/06/09 12:30 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I am using a stock pan in my 83 cordoba and it works fine with the windage tray as well. I tried to install a nice 318/340 milodon pan and pickup but it was a no go in the J-body....It is just taking up space in my garage..... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
