Small Block Stroker Oil Pan Question #185423
01/06/09 09:08 AM
01/06/09 09:08 AM
Central New York
DropTopE Offline OP
DropTopE  Offline OP
Central New York
I am lookoing into building a stroker using a 340 engine that I currently have. Can the stock oil pan be used? If not, what pans are people using on these. Reason for the question is that I was told by someone that he thought that the rod hardware hit the pan with the 4 inch crank - but he was not 100% certain.
Can anyoe help me out with this?
Thanks !
Re: Small Block Stroker Oil Pan Question [Re: DropTopE] #185424
01/06/09 09:12 AM
01/06/09 09:12 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i dont know if the stock pan will work. i think so but im not sure. i used the 8qt low profile milodon pan. there are two milodon pans but only one will work. i believe the 7qt pan wont work. use the milodon pan that ends with 35 and not 36
Re: Small Block Stroker Oil Pan Question [Re: DropTopE] #185425
01/06/09 09:14 AM
01/06/09 09:14 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Pan should be no problem but you may have to clearance the block depending on your rod choice. I didn't have to clearance anything with my 4 inch crank and CAT rods.This setup also neutral balanced
with no metal added.
Re: Small Block Stroker Oil Pan Question [Re: dmerc] #185426
01/06/09 09:58 AM
01/06/09 09:58 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Stock pan will work. I use the Kevko 6 quart M301. Since it has a built in crank scraper and baffles no need for a windage tray. Fits an a-body with TTI headers without issues:
http://www.kevko.net/mopar.htm
I am running Scat I-beams and block did not have to be clearanced with the 4" stroke.
Re: Small Block Stroker Oil Pan Question [Re: 69Cuda340S] #185427
01/06/09 10:47 AM
01/06/09 10:47 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I agree about the pan. I also used the scat I beam rods and crank with no clearance issues. Then my pan would not fit into the pickup so I still ended up buying a Milodon pan.
Re: Small Block Stroker Oil Pan Question [Re: Posest] #185428
01/06/09 11:14 AM
01/06/09 11:14 AM
Central New York
DropTopE Offline OP
DropTopE  Offline OP
Central New York
I am also forced to use a rear sump pan. Which Milodon did you end up with in your pick up?
Thanks for the replies so far - they have been very helpful.
Re: Small Block Stroker Oil Pan Question [Re: DropTopE] #185429
01/06/09 12:30 PM
01/06/09 12:30 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I am using a stock pan in my 83 cordoba and it works fine with the windage tray as well. I tried to install a nice 318/340 milodon pan and pickup but it was a no go in the J-body....It is just taking up space in my garage..... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Small Block Stroker Oil Pan Question [Re: tpabayflyer] #185430
01/06/09 02:05 PM
01/06/09 02:05 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Here's some info from the book "How to build big inch Mopar small blocks"
It has to do with windage & using a stock oil pan.
