Help identifying a couple of cams #1853905
06/21/15 06:19 PM
06/21/15 06:19 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Picked up a couple of small block cams, anybody recognize anything here?
RMNS 10:9-10
Re: Help identifying a couple of cams [Re: BLACK71] #1853906
06/21/15 06:20 PM
06/21/15 06:20 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
And
RMNS 10:9-10
Re: Help identifying a couple of cams [Re: BLACK71] #1853934
06/21/15 07:15 PM
06/21/15 07:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't know about the first one but look on page 52 of Comp Cams master lobe catalog.
Re: Help identifying a couple of cams [Re: BLACK71] #1853940
06/21/15 07:21 PM
06/21/15 07:21 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Will do thanks....supposedly the first one is an old suoprstock cheater cam
RMNS 10:9-10
Re: Help identifying a couple of cams [Re: BLACK71] #1853961
06/21/15 08:35 PM
06/21/15 08:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
The first picture is a old Cam Dynamics grind, Crane bought them out when C.D. was grinding and selling better cams than they could shock shruggy You may be able to still get that cam specs. from Crane scope Let us know what you find out up The last and most assured way of finding out what both cams are is to install and degree both of them in at .050 lifter lift and up and see what the actual lift and duration and lobe seperation is up twocentsEDIT. You could send them to someone who has a Cam Dr. and have them check and give you all the specs for them work I've done that also on one lobe for intake and exhaust to get all the info. needed to install and degree that cam. I won't do that now as I'm getting cheaper in my old age, so I check it myself now realcrazyshruggy
