Re: Wiper refills
[Re: Sir Valiant]
#1853669
06/21/15 09:36 AM
06/21/15 09:36 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I have hit all of our local stores including AZ and all of them have gotten rid of their inventory. The 43-160 Trico set on Amazon, are they the wide type? These need to fit original '64 arms. I have ordered three different sets from three different sources and they all are narrow.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Wiper refills
[Re: dfsmopars]
#1853842
06/21/15 04:00 PM
06/21/15 04:00 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
This was a couple of years ago, but for my 65 I found that the rubber was the same as modern ones and by reusing everything else but the rubber the fit was perfect. I did take the rubber part and matched it up at the parts store.
Re: Wiper refills
[Re: markz528]
#1853847
06/21/15 04:07 PM
06/21/15 04:07 PM
markz528
Morrow, OH
I looked it up - I bought them from Autozone and they were part number 91-18. These were for 18" Anco red dot wiper arms.
Re: Wiper refills
[Re: markz528]
#1853881
06/21/15 05:17 PM
06/21/15 05:17 PM
dfsmopars
Kentucky
ademon. Sorry that didn't work out.
markz528 I'll see if you info helps. The arms on the New Yorker are Anco and have the red dot. They also have the air diverters.
Re: Wiper refills
[Re: dfsmopars]
#1853885
06/21/15 05:26 PM
06/21/15 05:26 PM
dfsmopars
Kentucky
markz528 the 91-xx series are the whole blade looks like. They can be bought for sure. The blade is fine as long as the refill in it is 3/8" wide. Are the 91-18s you bought 3/8" wide?
Re: Wiper refills
[Re: dfsmopars]
#1853954
06/21/15 08:04 PM
06/21/15 08:04 PM
markz528
Morrow, OH
markz528 the 91-xx series are the whole blade looks like. They can be bought for sure. The blade is fine as long as the refill in it is 3/8" wide. Are the 91-18s you bought 3/8" wide? Not sure - I would have to check. But I can tell you they fit my 18 inch Anco red dots very well. Just the rubber part - I discarded the rest that came with it.
