How hot should a ballast resistor get? #185339
01/06/09 12:37 AM
01/06/09 12:37 AM
Someplace you aren't
SomeCarGuy Offline OP
I had power hooked up for the first time in over 4 years in my car tonight.
I was doing final checking before fire up and noticed smoke pouring out of the cowl with the key on for a few minutes while I reviewed things, like looking for smoke and fire to break out.
I checked all the wiring I could get my head in position under the dash.
I checked for wrong connections under hood.
I then rehooked things up and noticed that the fan runs even in "off", something I didn't recall about my car, so I unplugged it.
Next go around I had no smoke but the wires to the ballast and the ballast itself were VERY hot. I can't remember how hot they normally get.
The ballast looks new and might have been replaced as I sometimes pull parts off of nonrunners to get a car back up and running, then replace the nonrunners stuff later. I know a new ballast can smoke for a few seconds but...
I want my fair share
Re: How hot should a ballast resistor get? [Re: SomeCarGuy] #185340
01/06/09 09:14 AM
01/06/09 09:14 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
a ballast resistor gets really hot. especially if you just turn the key to on and leave it on without the car running. you are dumping a lot of power thru the coil with no off time so ya, it can get super hot.
burnt my fingers on mine once
Re: How hot should a ballast resistor get? [Re: SomeCarGuy] #185341
01/06/09 09:49 AM
01/06/09 09:49 AM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
ya it can get pritty hot -enough to burn up those mouse turds that were left behind it from four years of sittin
