broke crank in 383 #1852943
06/20/15 12:19 AM
06/20/15 12:19 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
welp, it happened! anyone else brake a steel crank from a 383?
Re: broke crank in 383 [Re: jcastle1] #1852973
06/20/15 12:56 AM
06/20/15 12:56 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
I ve NEVER seen a steel Chrysler crank break,
You got bad Ju Ju.
Re: broke crank in 383 [Re: jcastle1] #1852978
06/20/15 01:03 AM
06/20/15 01:03 AM
P
Porter67 Offline
Porter67  Offline
P
Sorry to hear that, but can we get some pics and what happened just to see a 383 steel crank busted as ive not seen one either.
Re: broke crank in 383 [Re: Randy..] #1853119
06/20/15 11:53 AM
06/20/15 11:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You got bad Ju Ju.
I have seen a few of them posted up over the years
Re: broke crank in 383 [Re: JohnRR] #1853148
06/20/15 12:46 PM
06/20/15 12:46 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I broke a 440 crank (forged OEM) into three pieces. #3 rod throw tried to exit the block, with # 6 rod & piston still attatched. I can't access the pictures till Monday, but it's ugly. Real ugly. The only thing salvageable below the camshaft is the swinging pick up and the drain plug.
Brian
Re: broke crank in 383 [Re: jcastle1] #1853157
06/20/15 12:54 PM
06/20/15 12:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you can't break a stock factory crank you aren't trying hard enough.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: broke crank in 383 [Re: pittsburghracer] #1853231
06/20/15 03:13 PM
06/20/15 03:13 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
i dont have the oil pan off yet, although i can turn the back of the crank and the balancer on the front dont move....
Re: broke crank in 383 [Re: jcastle1] #1853346
06/20/15 07:12 PM
06/20/15 07:12 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Did the block crack first?Have a look at the main webs when you get in there.
Re: broke crank in 383 [Re: jcastle1] #1853352
06/20/15 07:19 PM
06/20/15 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Seen one 383 crank break at the center main...two year old '69 RR.
Re: broke crank in 383 [Re: 67_Satellite] #1853582
06/21/15 12:34 AM
06/21/15 12:34 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
i didnt lose any oil, and there is no mess, so I will not really know until I disassemble. On another note, I got another block (440) ready for internals.Who has the best deal on rotating, balanced assemblies?
