Can you bluetooth music through U connect? #1853211
06/20/15 02:21 PM
06/20/15 02:21 PM
Cincinnati, Ohio
Challenger 1 Offline OP
Cincinnati, Ohio
Can we with our phone? Can't get it to stream music from my phone like my ford does. It's a 2007 300, can you stream music through it? TIA Got the phone connected to it and it works fine.
Re: Can you bluetooth music through U connect? [Re: Challenger 1] #1853312
06/20/15 05:53 PM
06/20/15 05:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Some newer cars only will connect Bluetooth through certain phones. Toyota will only connect via Bluetooth through Apple devices. Android based devices will not connect with new Lexus or Toyota vehicles.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Can you bluetooth music through U connect? [Re: Challenger 1] #1853353
06/20/15 07:32 PM
06/20/15 07:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I connect both my android and my blackberry to the UConnect in my '12 Dodge Caravan via bluetooth. Not sure I ever tried to stream music thru it as I have satellite radio.
Don't be the exception.
Re: Can you bluetooth music through U connect? [Re: fourgearsavoy] #1853830
06/21/15 03:42 PM
06/21/15 03:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
The phones are I phones, the phone part works fine, just see no where where I can select blue tooth audio like I can with my other car.
I am spoiled by my I pod and phone and won't listen to reg TV or radio because of too many commercials. If no I pod connection then I don't listen to anything.
This is a 2007 300 so it's older, but not even a plug in jack for a external source? I think our 2005 durango has a plug in jack for external sound?
Re: Can you bluetooth music through U connect? [Re: Challenger 1] #1853835
06/21/15 03:48 PM
06/21/15 03:48 PM
DC, MD Suburbs
440PURSUIT Online content
440PURSUIT  Online Content
DC, MD Suburbs
I was in my 09 Challenger last night and my son and I perplexed by the same thing. It would not stream throuh the USB cord either.
Bever got into AUX mode available
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: Can you bluetooth music through U connect? [Re: 440PURSUIT] #1853899
06/21/15 06:09 PM
06/21/15 06:09 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I was just trying this with the RER Mygig in our new to us 2008 Chrysler Aspen.
Couldn't get the wifegod's Iphone 6 plus to stream music although it had no problem pairing with U Connect.
It also didn't work through the USB.
From what I found the older units like mine will not stream music via Bluetooth to the system.
The USB will only work with music files and pictures.
The newer 2nd generation 2010 and newer? Mygig systems are able to stream.
I picked up a cheap 3.5mm male to male patch cord and go from the Iphone's headphone jack to the AUX input on the front of the Mygig.
It sounds great.
Re: Can you bluetooth music through U connect? [Re: Challenger 1] #1854254
06/22/15 12:08 PM
06/22/15 12:08 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
2014 Ram with U Connect, Android (Droid Bionic) and Bluetooth music shows plays through media connect. If the Droid is playing when the two mate on power up, the music starts automatically on the U connect.
