Rear Gen 3 Viper calipers on Front? Thoughts?
#1852471
06/19/15 12:51 PM
06/19/15 12:51 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Gen3 viper rear calipers have 42/38 Pistons which happens to be the same as gen 1/2 fronts, as well as having the benefits of radial mounting. Gen 3 rears also shared the same size rotor as Gen 3 fronts at 14" x 1.260". Would it be feasible to use these rear calipers on the front of a mopar as they can usually be had for quite a few bucks less than gen 3 fronts? What difference would you feel using a 13 or 14" rotor with the 42/38 Pistons vs. the 44/40 pistons?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: Rear Gen 3 Viper calipers on Front? Thoughts?
[Re: Fishmarket]
#1852610
06/19/15 04:29 PM
06/19/15 04:29 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The hydraulics work out but you're going back to a much smaller brake pad. Are the pads the same size as the stock front pads? The pads are what overheat and lose effectiveness in enthusiastic driving. Reducing their size won't be doing them any favors.
[Re: Fishmarket]
#1852635
06/19/15 05:05 PM
06/19/15 05:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
They use the same pad IIRC. I think Cass said you have to flip the transfer lines and bleeders because of how the rears are front mounted and the pistons are staggered.
Mopar to the bone!!!
[Re: Fishmarket]
#1852636
06/19/15 05:08 PM
06/19/15 05:08 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
They're the same size pads. Same calipers dimensionally, just with smaller pistons, and tubes / bleeders on opposite sides of the front gen 3 viper calipers.
I have a set in the rear, originally started with takeoff fronts in rear and front. I tried flipping the tubes and bleeders to match my original install, but gave up due to one tube thread being extra fussy. So just be aware- you'll need to run the rear-viper-calipers on the front side of the rotor in the front (if you want to bleed with them installed, anyway). Or you could pull them and stick a 1.25" aluminum block between the pads everytime you bleed them.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
