Dana 60 truck to car
#1851895
06/18/15 04:19 PM
06/18/15 04:19 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
I'm having a hard time locating a65-67 b body housing either 8 3/4 or Dana for my e body. Truck Dana diffs are easy to find. So is there a good base vehicle to grab one from ? I'm after a 3.54. I want to keep my wilwood disk brake kit so I want to cut one down and get aftermarket axles and get new bearing ends for the housing.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: Dana 60 truck to car
[Re: EV2CUDA]
#1851932
06/18/15 05:01 PM
06/18/15 05:01 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You have already answered your question...get a 3/4 ton Dana 60 truck housing, cut it down to fit, use big Ford housing ends, use sealed Ford bearings on 35 spline axles, use a PowerLock diff carrier for strength & longevity, 3.54 or 4.10 are easy to find to match the carrier, you will have to cut your driveshaft 1.12" to match the longer nose on the Dana, pinion yokes are available new in different sizes (use the strap style if you can) and make sure your u-joint matches the yoke, DAMHIK all this stuff.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1851940
06/18/15 05:17 PM
06/18/15 05:17 PM
EV2CUDA
Oh Canada
I don't think ford ends accept my disk kit for 8 3/4. Or does it? Looks like no. Mopar ends I guess if I want my brakes.
[Re: EV2CUDA]
#1852101
06/18/15 09:13 PM
06/18/15 09:13 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
There is a Dana 60, 4:10, Trak-Loc in my '74 W200 Dodge Power Wagon, but it's not for sale.
When I made a Dana 60 Truck-to-Car conversion 12-years ago, I got the donor Dana 60 out of a '72 Dodge B300 Van. It had 4:10 gears and a Trak-Loc.
It cost $73 at the local Pick-A-Part, Floating-Axle, drum-to-drum.
I had a donor 8 3/4 housing in my collection, so cut the bearing ends off and a local shop grafted the ends on, inspected and checked the tooth pattern/setup, etc, for $200 total.
I had a set of 30-spline 8 3/4 aftermarket axles (which fit the 30-spline Dana 60 Truck differential). Had to have one axle shaft cut shorter by an inch.
35-spline axles are better. To install, you need to buy some 35-spline side gears. I just saw a New set of side gears for $100 on eBay.
[Re: EV2CUDA]
#1852623
06/19/15 04:52 PM
06/19/15 04:52 PM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I got my dana out of a 72 Ford 3/4 ton truck. There either 3 inch or 3 1/8 A older ford 4x4 will have a dana
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
