Parking brake cable routing #1852205
06/18/15 10:08 PM
06/18/15 10:08 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I am putting a 70 V code Cuda back together that was a race car most of its life. It has no rear brake cables. Does any one have a pic of how they are routed and the length of the 2 rear cables. It has 11 inch rear brakes. I have some cables that I was told were right but they don't seem to line up where I think they should. Maybe they are just missing a clamp. Thanks in advance, Rod
Real Men shift for themselves
Re: Parking brake cable routing [Re: 1DGEMAN] #1853187
06/20/15 12:32 PM
06/20/15 12:32 PM
La Habra, CA
70440SIXPK Offline
70440SIXPK  Offline
La Habra, CA
Rod,
Please check your email. I have sent you some photos showing proper location.
1970 Challenger
Factory V Code
Re: Parking brake cable routing [Re: 1DGEMAN] #1853260
06/20/15 03:26 PM
06/20/15 03:26 PM
WA
tman Offline
tman  Offline
WA
Im in a similar dilemma. Would appreciate those photos too.
Thanks in Advance
Re: Parking brake cable routing [Re: tman] #1853269
06/20/15 03:44 PM
06/20/15 03:44 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Here you go..
Re: Parking brake cable routing [Re: 1DGEMAN] #1853274
06/20/15 03:55 PM
06/20/15 03:55 PM
WA
tman Offline
tman  Offline
WA
Thanks for the diagram. Photos actually will help with exact locations and enhance the diagram.
Re: Parking brake cable routing [Re: Chally426] #1853351
06/20/15 06:19 PM
06/20/15 06:19 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Great diagram but not the correct one for this car. It has a long cable on the right side and a short cable on left. They fit in a bracket on left side and join up with the front cable and adjuster equalizer. There are some pics in this thread (1970 Challenger Muffler Bracket Trunk Pan Hole Location)and this thread (challenger muffler bracket location?) Thanks to 70440SIXPK for the pics.
Hope this helps,Rod
Re: Parking brake cable routing [Re: 1DGEMAN] #1854799
06/22/15 10:12 PM
06/22/15 10:12 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hope this helps,Rod
And you're exactly right...the diagram is the later E brake system..Here's a 70 diagram..
Re: Parking brake cable routing [Re: 1DGEMAN] #1854802
06/22/15 10:15 PM
06/22/15 10:15 PM
Harrisburg, Pa.
Harrisburg, Pa.
Detail of various areas...
Re: Parking brake cable routing [Re: 1DGEMAN] #1854813
06/22/15 10:26 PM
06/22/15 10:26 PM
Harrisburg, Pa.
Harrisburg, Pa.
Parking brake cable part numbers...
