Re: Can't stop the percolation!
[Re: ColorMeGreen]
#1851919
06/18/15 04:45 PM
06/18/15 04:45 PM
Posts: 3,384 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Is your problem with the engine overheating, or fuel boiling in the carb bowls (vapor lock), or both?
Those are two completely separate problems with two different types of solutions.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: ColorMeGreen]
#1852085
06/18/15 08:50 PM
06/18/15 08:50 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Make sure the fuel line is not running close to the exhaust in the rear axle arch or under the car. Be sure it's not laying on the engine either.
I had a fuel issue like that on the Power Tour a couple years ago. It turned out to be a bad fuel pump.
Find a fan shroud. Lose the pusher.
I went through countless electric fans ovr the years trying to keep cars cool in Texas. Every pusher I tried made things worse at speed, running or not.
I have run blocked heat risers for ages. Things are different in Texas and we generally don't need them. PA is likely a different story.
[Re: ColorMeGreen]
#1852112
06/18/15 09:30 PM
06/18/15 09:30 PM
Posts: 5,846 ohio
ruderunner
ohio
0* timing? Really? And it runs good there? The seriously retarded timing is causing hot running. But why is that the best timing you can run? Something is wrong here, tell us more about the details for your combo.
Angry white pureblood male
[Re: ruderunner]
#1852126
06/18/15 09:40 PM
06/18/15 09:40 PM
Posts: 21,830 Kirkland, Washington
Pacnorthcuda
0* timing? Really? And it runs good there? The seriously retarded timing is causing hot running. But why is that the best timing you can run? Something is wrong here, tell us more about the details for your combo. I totally agree. Your timing numbers are horrendous (so far). You either need a dial back Tlight or a degreed damper in order to provide additional info.
[Re: Pacnorthcuda]
#1852140
06/18/15 09:59 PM
06/18/15 09:59 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
X3 on the timing. My old Chiltons Manual says 5 degrees BTDC for a '72 400 Automatic 190 HP(2 barrel), 10 degrees BTDC for 265 HP Fresh Air 4 Barrel motors. And that's for a stocker.
[Re: ColorMeGreen]
#1852176
06/18/15 10:45 PM
06/18/15 10:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No shroud
overheats at idle
pusher fan
Once you set your timing to the proper mark and if you still have an overheating at idle issue get rid of the pusher fan, put a shroud on it and get rid of the 160 degree thermostat.
[Re: ColorMeGreen]
#1852384
06/19/15 05:54 AM
06/19/15 05:54 AM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Perhaps you could get a Squarebore intake or switch back to the Thermoquad carb? The Thermoquad should perform better with regard to fuel temp. Then you could go back to using a heat insulating spacer as well.
My '71 Charger, 440, had similar overheating and vapor-lock issues.
As for the cooling system, I had replaced everything, hoses, belts, water pump, 180-degree T-Stat, flushed the cooling system, shroud in place, new fan clutch, checked timing, checked for pressure leaks, it still overheated.
Turned out to be a calcified radiator. A local shop re-cored tanks with 4-cores, of newer high-efficiency type tube/fin replacements, and that solved it. Can now Idle for extended periods on 105-degree days, drive in stop-go traffic, run at the strip, and it stays under 200.
As for the vapor-lock, boiling fuel, I mounted a heat isolating spacer AND a Holley aluminum heat-deflector plate under the carb. I also insulated the fuel lines in the engine compartment and switched to a bypass type fuel-regulator with excess fuel return-line to the fuel tank.
You might be Ok with just the insulating spacer and perhaps a heat deflector plate.
Good luck.
[Re: ColorMeGreen]
#1852485
06/19/15 01:39 PM
06/19/15 01:39 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I'm not sure I can fit a thermo spacer at this point, I'm already using an adapter for the spreadbore manifold to the square bore carb.. The factory choke is barely in reach and the throttle and kickdown is noticeably raised. What a mess, is the choke even working properly? You need to change the intake, lose that adapter and block the heat crossover FIRST. What car are you working with, what do you have for a distributor, what cam? If your distributor is a stock one you just can't willy nilly advance the initial timing without making changes because you will have too much total advance, which is going to cause other problems.
