air grabber vacuum canister and switch #1851825
06/18/15 02:59 PM
06/18/15 02:59 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
Still trying to get air grabber working properly. First I can hear vacuum leak in switch. Its not were lines plug on but inside switch. Normal or bad switch? Next the vacuum canister should it hold vacuum? If I put gauge on center fitting and a mighty vac on vacuum side and pull vacuum it will not hold it and I can only get barley 1" and it bleeds off. Is this normal? Thanks Moparts
Re: air grabber vacuum canister and switch [Re: stateroadhog] #1851858
06/18/15 03:31 PM
06/18/15 03:31 PM
Owosso, Michigan
Owosso, Michigan
Just a quick update found a pin hole in cannister. If cannister is leaking and switch is leaking then I have a vacuum leak effecting motor correct?
Re: air grabber vacuum canister and switch [Re: stateroadhog] #1851865
06/18/15 03:37 PM
06/18/15 03:37 PM
Norway
General 68 Offline
General 68  Offline
Norway
Correct.
