Still trying to get air grabber working properly. First I can hear vacuum leak in switch. Its not were lines plug on but inside switch. Normal or bad switch? Next the vacuum canister should it hold vacuum? If I put gauge on center fitting and a mighty vac on vacuum side and pull vacuum it will not hold it and I can only get barley 1" and it bleeds off. Is this normal? Thanks Moparts
Just a quick update found a pin hole in cannister. If cannister is leaking and switch is leaking then I have a vacuum leak effecting motor correct?
