Okay fellers,time to make some predictions.Only 2 months till launch time.
This will be 1/8th mile only also.
4.500x4.500 572 C.I.D.
callies crank.
6.950 grp rods
Wiseco flat tops
Zero decked blocked with 15.1 compression
572-13 indy 385 cnc heads with titanium valves
and 1.7 rockers
Indy tunnel ram with 2 750 alcohol dominators.
TCI 9 1/2 inch convertor that went to 6000 behind my 528..
Only downfall is i am using the camshaft out of my 528 which was with 1.5 rockers and the specs were
intake lift 700 exhaust lift 715
duration 326 and 356
duration @50 286 and 306
112 degree centerline
This motor will be going in a (i know but its still mopar)1900lb 240" 4 link dragster with a 4.30 gear.
Just curious to see what some guesses are out there.
Thanks for playin.
