Re: 16.5 Inch Standard Wheels, W200 Pickup, Change to?
[Re: D_C]
#1851624
06/18/15 05:58 AM
06/18/15 05:58 AM
Posts: 3,265 Pyeongtaek, South Korea
69HemiGTX
16.5s are still out there, but your choices are very limited. Find a later model truck (90-93) in the junkyard and get the wheels off it. I say 90-93 becuase I'm sure they came with 16s. I still haven't figured out when the switch from 16.5s to 16s occured, but I know it was before 1990.
OIF V and OEF X veteran and proud of it!
[Re: rumblebee4232]
#1851721
06/18/15 12:14 PM
06/18/15 12:14 PM
Posts: 516 ND
dodgedon
ND
I had 16.5 on my 85 W350. I went up to the 17" wheels. Lots of nice radial options out there for the newer trucks that are using 17's. If you want aftermarket wheels the sky is the limit for options. But is you are looking for a stock look, i know guys that are using the 16" wheels off the Ford E series van. I believe they are a wider rim. Maybe 7". My dads 90 W250 had a 16x6 wheel from the factory.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
