2000 Dodge Caravan and no heat? #185134
01/05/09 10:22 PM
01/05/09 10:22 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Any techs might give me a clue where to start looking. The heat gauge is working so I know the motor is getting hot enough. Is there a valve or something? I have a service manual for a 1996 so I can look at it for reference if they are the same.
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185135
01/06/09 12:15 AM
01/06/09 12:15 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I've run into some of the 4 cylinders having the water pump impellers spinning freely. take off the radiator cap, and make sure the water is circulating. if not, then aim for the water pump.
Re: 2000 Dodge Caravan and no heat? [Re: 1965_PLYMOUTH] #185136
01/06/09 01:14 AM
01/06/09 01:14 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This a v-6 3.0 but I will check that.It has not been getting hot at all.
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185137
01/06/09 02:28 PM
01/06/09 02:28 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185138
01/06/09 02:55 PM
01/06/09 02:55 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check the heater hoses for temp.
Re: 2000 Dodge Caravan and no heat? [Re: stumpy] #185139
01/06/09 05:07 PM
01/06/09 05:07 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
will try that tonight. Thanks
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185140
01/06/09 07:15 PM
01/06/09 07:15 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
My wife just pulled in and I tried to find the heater hoses. Man what a jungle. When I first cut the heater on, it put out hot air. It cooled off pretty quick. If what I found are the heater hoses, then they are both hot. I will have to look in the service manual to learn more. Just hoping that a tech new of a common problem on these things.
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185141
01/06/09 07:23 PM
01/06/09 07:23 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
everything seems to run off the pcm computer, disconnect the battery and let it sit for 2 minutes and reconnect...see if that works for ya....seems to solve alot of problems with these models...
Re: 2000 Dodge Caravan and no heat? [Re: AARCONV] #185142
01/06/09 07:30 PM
01/06/09 07:30 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Is the temp gauge in the middle,if not you need a thermostat.
Re: 2000 Dodge Caravan and no heat? [Re: SALEM1912] #185143
01/06/09 08:03 PM
01/06/09 08:03 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Temp gauge is in the middle.
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185144
01/07/09 12:32 AM
01/07/09 12:32 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, made it to the shop with the mini van and started looking. Heater hose under the dash were both hot and the blend doors worked. Opened the hood to do some looking and found some red residue on the tank under the fill cap. Scraped it off and found a small crack in the tank. Opened the cap and no water was visible. Filled it up with about 3/4 gallon of water and heater works great! I kept the coolant reservoir filled in the Summer and Fall so it did not leak out fast enough to get engine hot. That is why the heater worked on the last trip we took in about Oct. Lucky it did not get hot. My wife never watches gauges. Got lucky this time. Now for a new rad. What kind of coolant is this special stuff it says to use on the overflow tank? Or should I just use the old Prestone stuff?
Re: 2000 Dodge Caravan and no heat? [Re: fastmark] #185145
01/07/09 12:32 PM
01/07/09 12:32 PM
MNobody Offline
MNobody  Offline
Isn't there a way to fix the crack in the tank while in the vehicle and save alot of work and money? Just a thought.
Re: 2000 Dodge Caravan and no heat? [Re: MNobody] #185146
01/07/09 07:55 PM
01/07/09 07:55 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, maybe. I would hate for it to break on an out of town trip. Called today and got a rad on the way for $105 plus shipping.
