Re: surging idle
[Re: 2JcodeChargers]
#1851028
06/17/15 12:50 PM
06/17/15 12:50 PM
RapidRobert
vac leak. dist weights moving at that idle speed. gummed up carb idle circuit (too lean=not enough fuel to support a stable idle). EDIT not enough initial?
Re: surging idle
#1851044
06/17/15 01:27 PM
06/17/15 01:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did you also check the throttle shaft to carb body mating points for leaks. As that point wears you can get erratic idle issues.
Re: surging idle
#1851096
06/17/15 03:01 PM
06/17/15 03:01 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Did you have this issue 2 years ago ?
What is the cam , stock or something with LESS idle vacuum ?
Re: surging idle
#1851602
06/18/15 03:23 AM
06/18/15 03:23 AM
RapidRobert
spray the shaft on both sides & make sure the vapors dont go up along the carb sides & get sucked in the air horn & give you a false reading (piece of cardboard or paper)
