Re: total seal rings file fit or gapless top [Re: PorkyPig] #1850681
06/16/15 09:19 PM
06/16/15 09:19 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Called Mahle today. They claim they have a standard 3mm low drag oil ring. Call total seal to see if they had low drag standard oil ring and they just about laughed at me. Said all standard 3mm oil rings have same drag at about 13lbs. Maybe I should have started this thread asking which rings are best for my application in a .043/.043 3mm file fit?
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850697
06/16/15 09:45 PM
06/16/15 09:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dave.....
The little engine masters 318 motor I bought has 043 ring pack.
The builder " crimped" the oil ring, has 8 pounds of drag. Not sure exactly how that's done, it seated good and the motor runs great.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850718
06/16/15 10:18 PM
06/16/15 10:18 PM
Mt Morris Michigan
Mt Morris Michigan
Did you buy that engine from mike in chessening? Standard oil ring? No smoke?
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850735
06/16/15 10:31 PM
06/16/15 10:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No. Adney Brown, owner of Performance Crankshaft in Detroit, who built it.
No smoke.
Think the engine build article said the oil ring was low tension to begin with , then the expander was crimped.
You can google the build article, it's interesting reading about building an engine in general.
" LA confidential, popular hot rodding"
1.41 best 60 foot
6.60 at 103.90 1/8
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850745
06/16/15 10:46 PM
06/16/15 10:46 PM
Mt Morris Michigan
Mt Morris Michigan
Dwayne welder has my heads and is a friend of Adney. I'll asked dwayne and see what he knows. Thanks
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850766
06/16/15 11:05 PM
06/16/15 11:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The reason for the "laugh" as you call it, is because Mahle told you something, or at least the way you phrased it, that is impossible. No such thing as a standard tension "low drag" oil ring. The drag is based on tension and standard tension, is standard tension. Plus ALL the scrapers are the same, so tension is varied only by the expander, which never touches the cylinder wall..........Now Mahle MAY have meant that they have a standard(meaning shelf) "set" which includes a "low drag" oil ring, which would make sense, but that's not what you said here or apparently to Total Seal
If you WANT a low tension oil package, they can definitely make you one.....just tell them what you want for pounds and they will make it happen. The way this is done is by varying the size of expander. The MORE expander you cram in the groove, the MORE tension and vice versa. So lets say your bore size is 4.060 and they send you an expander for a 4.00 bore set, you have less tension. They KNOW all this and can give you exactly what you ask for. Too many people worry about "shelf" sets and settle for what they can get, when all you have to do is tell them what you WANT.
"Crimping" an expander, simply means you take some pliers and squeeze a few sections of expander tighter, so that it can't expand as much. HOW MUCH and HOW MANY.....only VERY experienced builders who have done it before can answer that. The ONLY reason you do that, is to make the oil ring expander you HAVE into a lower tension one, in lieu of just ordering what you need
Re: total seal rings file fit or gapless top [Re: Monte_Smith] #1850799
06/16/15 11:38 PM
06/16/15 11:38 PM
Mt Morris Michigan
Mt Morris Michigan
That's what I figured. And yes mahle did tell me they had a standard tension "low drag" oil ring. I was under the impression that total seal rings were the best. Sounds like some others are just as good. I told total seal what I was doing and he gave a crh0010-45, which is a standard tension file fit with moly top ring.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850920
06/17/15 03:52 AM
06/17/15 03:52 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Personally I run nothing but Total Seal brand rings or Ackerly & Childs in high performance motors
