Have him remove the rocker arms and spark plugs and see how much break away and rotational torque is needed. Dick Landy told me years ago to look for 21 to 25 ft. lbs break away and 15 to 18 ft. lbs rotational both ways
EDITED: That was on a new short block with standard rings back then, 1/16,1/6, 3/16 low tension oil rings with a fairly rough bore
.Once the motor is ran it will turn over a lot easier with broken in rings and cylinder walls
My last bracket motor ended up having 1.5 MM,1.5 MM and 3.0 MM oil rings with really smooth cylinder walls
I didn't think to measure it for breakaway and rotational torque but it was way easier to turn over than the same combination in a different block with 1/16,1/16, 3/16 standard tension oil rings
