Re: Towing with a 1985 B250 Dodge Roadtrek (maxi van rv ) [Re: Cab_Burge] #1848152
06/13/15 04:00 PM
06/13/15 04:00 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By Cab_Burge
None of the Dodge van type chassis (motor home or industrial appication also) where designed to pull much weight due to them not having a conventional frame work scope A freind of mine bought a 1 ton class B Dodge motor home to tow his race car, the rear side door didn't close well and when he went under it to service the rear end he found that the rear subframes where cracked and bent shock down He ended up scrapping it :shruggy Buy a truck with a frame up twocents
I was following this thread and wondering if anyone would mention the fact that vans are uni-body, and as such, have mild steel sheet metal rear frame rails, just like our favorite cars. Wasn't sure of particulars so kept quiet. I would agree with a camper in a heavy pick-up as well.
I have mechanical Aptitude.
I can screw up anything.
Re: Towing with a 1985 B250 Dodge Roadtrek (maxi van rv ) [Re: johndart] #1850150
06/16/15 12:59 AM
06/16/15 12:59 AM
Toronto, Ontario, Canada
johndart Offline OP
johndart  Offline OP
Looks like I may have to re think this.
Thanks for all comments, concerns, suggestions, opinions and sharing of experiences.
