Re: Another caltrac ??
[Re: Gary Robbins]
#1849705
06/15/15 04:07 PM
06/15/15 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
And looking at your shock you have very little for the compression of it... so between the shock travel and the shock stiffness it would be bouncy EDIT And thats not even with you in the car.. you would have less compression travel on it
[Re: dizuster]
#1849730
06/15/15 04:59 PM
06/15/15 04:59 PM
Thumperdart
State of confusion
Unless you weigh 400 lbs. those are fine and I have 2" left for compression and never bottom out. I see the rubber stops and a bit of shaft showing.........
[Re: Thumperdart]
#1849744
06/15/15 05:22 PM
06/15/15 05:22 PM
MR_P_BODY
Unless you weigh 400 lbs. those are fine and I have 2" left for compression and never bottom out. I see the rubber stops and a bit of shaft showing......... I see 3/8" shaft then the rubber starts stacking up...that rubber gets hard real fast... but you have 2" of travel... thats 2 different worlds
[Re: mshred]
#1849764
06/15/15 06:03 PM
06/15/15 06:03 PM
BradH
Mine is bouncy also, especially with the shocks stiffened up for the track...I just deal with it though, its not a cadillac and im ok with that lol x2... I don't change the settings for the street when I've gotten it dialed in for the track.
[Re: MR_P_BODY]
#1849766
06/15/15 06:05 PM
06/15/15 06:05 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Unless you weigh 400 lbs. those are fine and I have 2" left for compression and never bottom out. I see the rubber stops and a bit of shaft showing......... I see 3/8" shaft then the rubber starts stacking up...that rubber gets hard real fast... but you have 2" of travel... thats 2 different worlds I'll check how much shaft is showing and also thinking there's 2 stops stacked...maybe removing 1 stop will help...It's not crazy rough,just enough to be enoying !!
[Re: Gary Robbins]
#1849772
06/15/15 06:20 PM
06/15/15 06:20 PM
MR_P_BODY
Yeah take one of them off... you should still have plenty of snubber with one... I dont know why guys dont back off the shock setting... I guess they cant count
[Re: Gary Robbins]
#1849832
06/15/15 07:44 PM
06/15/15 07:44 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i run the rancho rear shock , loosen it 4 clicks for the street . Its fine .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#1849868
06/15/15 08:09 PM
06/15/15 08:09 PM
MR_P_BODY
On my car it's as much the pre-load as the shock damping setting. Twisting the adjusters is no biggie, but changing the pre-load simply to soften up the ride on the street isn't worth my time once I've gotten it where the car hooks and launches straight off the line. Cut a reference line in the 2 spots so you can get back to it easy... unless you feel its not that stiff(when I say cut... I mean grind a mark... I would use my .040 cut off wheel)
