total seal rings file fit or gapless top #1849288
06/15/15 12:58 AM
06/15/15 12:58 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
will be ordering pistons and rings in the next week or two. ordering wiseco nitrous domes for the 410sb. will be 4" stroke 13.5:1 and spin between 7000-7500 shift points. n/a application and will see some street time. looking at total seal for rings. the pistons use the .043/.043/3mm ring. what should I get, file fit or gapless? why? thanks
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849375
06/15/15 03:52 AM
06/15/15 03:52 AM
I'm almost sure that Total Seal doesn't make, use or recommend a gapless ring in .043, if they do I wouldn't use them down twocentsGet a really good set of rings for the dual purpose appilcation with that much compression up I'm not sure if the top should be moly and a second Napier iron ring or which package is the best for your deal, sorry shruggy
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849391
06/15/15 06:04 AM
06/15/15 06:04 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No gapless....
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849513
06/15/15 12:25 PM
06/15/15 12:25 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks to both of you. i will stay away from gapless. just curious to why?
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849554
06/15/15 01:14 PM
06/15/15 01:14 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just spoke to Total Seal about rings for my 434 build, pump gas street/strip deal, probably 11.3-5 to 1 compression, solid roller 260-270 @ .050, low .700 lift with Indy 360-1s. For this combination they recommended a gapless top, napier second and standard tension oil ring, 1.5mm, 1.5mm, 3.0mm.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849564
06/15/15 01:25 PM
06/15/15 01:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO it is a "gimmick" 99.9% of the time Total Seal will recommend something other than gapless. Total seal I think might agree if cornerd and also likely why they went to a gapless top ring. IMO it is just old antiquated thinking.
To oversimplify it. The issue is with a gapless second you will loose ring seal on the top ring due to increased pressure that gets trapped by the second gapless ring. Nowadays most top engine builders actually OPEN up the gap on the second ring to allow any excess pressure to be forced down, also helping to scavenge oil off the cylinders.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849621
06/15/15 02:36 PM
06/15/15 02:36 PM
Washington
madscientist Offline
Washington
Use a gapless top. Open the second a bit.
The reason I use them more than most is that most guys don't want to experiment with end gaps. I have a BLOW BY METER that I use on the dyno and under load the gapless are ALWAYS better than gapped rings that are nottested. Most times, you can run the minimum gap called out, or a little less, as long as you torque plated the block and use the torque plate to gap rings.
Re: total seal rings file fit or gapless top [Re: madscientist] #1849635
06/15/15 02:52 PM
06/15/15 02:52 PM
Mt Morris Michigan
Mt Morris Michigan
i just called total seal myself to get a part number for rings i will need. they recommend gapless top for my combo as well. $347/set, ouch!
what do you like to see for ring gap on second ring?
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849666
06/15/15 03:17 PM
06/15/15 03:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Gapless top rind is a diferent deal. Still while I do not hundreds of engines under my belt I try to surround myself with smart people who do and most will say they don't like them. They do give the end user a false sense of calm with leak down numbers for sure but most top tier guys do not put a lot into leak down numbers either. Compression numbers yes, leakdown not so much. I could see why some engine guys use them for that very reason alone. They will show excellent "seal" with a leakdown test so makes them look good.
FWIW $347 for a set of rings is not bad at all. My predator stuff was about $1500 more than that, just saying. As for the second gap depends on intended use, block material and ring selected IMO.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849669
06/15/15 03:20 PM
06/15/15 03:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
They definitely do make a gapless .043 Top..........would I run them......NO. Am not a fan of gapless top rings. The reason is they never SHOWED me anything in regards to POWER. Great leakdown numbers and less on the blowby meter is fine, but does that equal more POWER and the car running faster. In our own Super Stock motors, that was not the case and we tried every ring combination there is
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849670
06/15/15 03:21 PM
06/15/15 03:21 PM
Washington
Washington
That's basically what I was saying. Without a blowby meter (or something similar) you only have leak down and compression testing and the gapless top always looks good in those.
The only issue with using the blow by meter is using vaccuum pumps and dry sumps. You can't use the blow by meter with them (at least I have not found a way to do it yet) so it will skew readings and make a good ring package look bad. As with all testing you need to be very careful otherwise the numbers mean nothing.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849672
06/15/15 03:23 PM
06/15/15 03:23 PM
Washington
Washington
I usually start with the second ring gap in the middle of what is called for in your application.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849699
06/15/15 03:58 PM
06/15/15 03:58 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I'll chime in.
Don't like gapless rings tried it both ways with and without. Engine vacuum the same engine performance the same when the rings a worn out the leak down will still say it's good.
It's a waste of money and all the time it takes to file fit so why run them no performance bump no benefits.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1849850
06/15/15 07:59 PM
06/15/15 07:59 PM
crabman173
crabman173
Did you say NOS pistons? So..you are going to spray?
I would think that a 1/16th NOS ring package would be in order
Skinny rings are hot right now and make more HP but in a Spray Motor?? Not me..
Gapless has never shown me more HP on the dyno--they make great leak down test--I would maybe use them in dirt track engines that eat lots of dirt , hoping it might delay fresh up a little but even that is big maybe
I think from all I have seen and built it is a gimmick and and expensive one!
Re: total seal rings file fit or gapless top [Re: ] #1849870
06/15/15 08:10 PM
06/15/15 08:10 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
A few years ago I tried gapless rings when I freshened up the motor in my Demon. It was a wast of money. I saw zero difference in performance or anything else except less money in my pocket. I also ran a small shot of nitrous sometimes.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: total seal rings file fit or gapless top [Re: ] #1849958
06/15/15 09:30 PM
06/15/15 09:30 PM
Mt Morris Michigan
Mt Morris Michigan
No. That's just what wiseco named them (nitrous dome). This is a n/a engine. The total seal file fit .043 is still pricey at $189.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850133
06/16/15 12:25 AM
06/16/15 12:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Price a set of 1.5, 1.5, 3.0 mm, $297 for traditional ring and $387 for a gapless top ring.
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850177
06/16/15 01:30 AM
06/16/15 01:30 AM
Mt Morris Michigan
Mt Morris Michigan
do you think that the total seal rings are the best performance rings to buy?
Re: total seal rings file fit or gapless top [Re: ] #1850180
06/16/15 01:32 AM
06/16/15 01:32 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We run .043 top and second rings in 900" nitrous motors that spray 1200+HP of nitrous, in addition to the 1600 they make on nuts
Re: total seal rings file fit or gapless top [Re: mopar dave] #1850654
06/16/15 08:32 PM
06/16/15 08:32 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
IMO, no. They offer rings in a whole bunch of sizes and styles, but I don't think that means they're the best. Not that they make bad rings (I've used them before and will again), but Mahle, Hastings and Speed Pro make a good ring, too.
