AOD kick down ?? #1849224
06/15/15 12:13 AM
06/15/15 12:13 AM
mn
flyman Offline OP
flyman  Offline OP
mn
How much slack do I need on a 1995 A518 kick down linkage? I used a older mechanical linkage not the cable type. Thanks MOPARTS
Re: AOD kick down ?? [Re: flyman] #1849330
06/15/15 01:28 AM
06/15/15 01:28 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I set mine up to fully push the kick down lever back on the trans at full throttle. Works perfect that way with the stock 83 linkage.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: AOD kick down ?? [Re: flyman] #1850625
06/16/15 07:23 PM
06/16/15 07:23 PM
BDW Online content
BDW  Online Content
Blast from the past, but still holds true.
https://www.youtube.com/watch?v=FY9WTWayCC8
Re: AOD kick down ?? [Re: flyman] #1850631
06/16/15 07:37 PM
06/16/15 07:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might do an "how do you do it" search on line and see if there is a video. There is a tab you have to release and either push or pull the cable housing to set it right. I'm not sure which way so I recommend looking for the video.
