just lost my only key... #1849049
06/14/15 09:35 PM
06/14/15 09:35 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
to my 1971 dodge truck---never had a key for the doors---question--source for new ignition and matching door locks----on a chevy it is not so hard---$25 and you get all three---on dodge searched i find only the ignition or only the 2 door locks.....bob----continued searching found jims auto parts with set for $160--cute gold keys---and carslocksandkeys.com has a truck set for 49.95...thanks for looking....bob
Re: just lost my only key... [Re: savoy64] #1849300
06/15/15 01:06 AM
06/15/15 01:06 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Pull the ignition lock cylinder and a door lock cylinder, take it to a locksmith, and have keys made for about $50-$75. If you buy a set, don't buy from Jesser like I did once. Their "NOS cylinders" were actually used and fell apart.
Re: just lost my only key... [Re: topside] #1849469
06/15/15 11:39 AM
06/15/15 11:39 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No need to pull anything, I've had Locksmiths make keys on site, without removing the locks/cylinders, call a qualified tech who has the tools/knowledge, can be done in under an hour, and under $100
Re: just lost my only key... [Re: DAYCLONA] #1852717
06/19/15 07:10 PM
06/19/15 07:10 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
iagree They come right to your house and make a new key in 15 minutes.
Probably run you 75.00.
Re: just lost my only key... [Re: savoy64] #1854322
06/22/15 01:57 PM
06/22/15 01:57 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
When you replace the lock cylinder in the steering column the easiest way to remove if is with the key. Since you do not have one, you will have to drill it out, hoping you do no damage. Better bet is with a locksmith. I had it done on my 68 Fury years ago. Since my locks matched, He used the passenger side door lock (the least used lock). He shined up a key blank with steel wool and inserted it with a vice grip pliers. He moved it back and forth and looked at the scratches from the tumblers to determine the notches. He took a small triangular file and cut them, shined the blank, wiggled the key again. When the tumblers stopped scratching, the tumblers were matched and he stopped filing them and suddenly the lock turned. He left me the crude key and went to his shop and calculated the code for the key and cut it for me to factory specs. Worked like a champ in all cylinders. Made several copies so that it would not happen again.
Craig
Re: just lost my only key... [Re: savoy64] #1855858
06/24/15 12:59 PM
06/24/15 12:59 PM
france
jose jones Offline
jose jones  Offline
france
When you get this fixed make about 5 sets of keys for it
