Looking for a Tach: Need advice! #184874
01/05/09 07:27 PM
01/05/09 07:27 PM
United States
STLDuster Offline OP
United States
I am looking in to aftermarket tachs for my Duster. I like the idea of having a larger (3-3/4"?) mounted on my console up by the dash pointing up towards me but I am not against a smaller one mounted on the steering coloumn. I have never actually set one of these up before, seems straight forward enough. I would prefer to get an American made piece, I believe Stewart Warner is American made but... I don't know much about them and could be mistaken.
Any advice on shopping around for one, any particular style to stay away from or anything to be on the look out for, is one less acurate than another or known to be problematic?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184875
01/05/09 07:33 PM
01/05/09 07:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have always had good luck with American made Autometer products.
As far as size goes...sort of depends on you. Maybe mock up something and put it in a few locations to see where is the best for you ?
Re: Looking for a Tach: Need advice! [Re: OzHemi] #184876
01/05/09 07:55 PM
01/05/09 07:55 PM
Cochise County Arizona
SPWC Offline
SPWC  Offline
If youre drag racing I suggest you maount it on the column or Dash,this way you wont have to take your eyes off the track to look at your tachometer.
If youre just puttering around or cruising,then under the dash,near the ashtray might not be a bad place,as youll only be using it for reference at times anyway.
Re: Looking for a Tach: Need advice! [Re: SPWC] #184877
01/05/09 08:00 PM
01/05/09 08:00 PM
United States
United States
I am not going to be racing it too much, at least not at first. Mostly going to be on the street. I put the engine together with the original cast crank so around 5 grand I am going to start to panic.
Thanks for the advice!
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184878
01/05/09 08:37 PM
01/05/09 08:37 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Yeah the cast crank is more than adequate for well over 5,000rpm
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Looking for a Tach: Need advice! [Re: 69L78Nova] #184879
01/05/09 08:49 PM
01/05/09 08:49 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
IMO, there is no other choice than Autometer, or their economy brand-AutoGage. I actually have a used 5" AutoGage tack mounted on my a-pillar in my truck, just above my dash. It was free, so I figured why not. Hook up was very easy, and Autometer's website even offered instructions for hook up and setup. Eventually, I would like to make a custom dash panel with all Autometer gauges.
Re: Looking for a Tach: Need advice! [Re: dodgeram440] #184880
01/06/09 01:07 AM
01/06/09 01:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I run the Autometer white face 8K tachs in every car or truck I build.
Hookup is easy. Orange wires are lighting. Sometimes you can find an unused pigtail to hook right into- no splicing.
I want my fair share
Re: Looking for a Tach: Need advice! [Re: SomeCarGuy] #184881
01/06/09 09:16 AM
01/06/09 09:16 AM
United States
United States
Thanks guys!
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184882
01/06/09 01:52 PM
01/06/09 01:52 PM
United States
United States
What do you guys think of the Auto gage Monster Shift-Lite Tachometers?
http://store.summitracing.com/partdetail...mp;autoview=sku
http://www.autometer.com/cat_gaugedetail.aspx?gid=2472&sid=1
I think I can get one used locally...
--- posted the wrong one, it should be corrected now ---
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184883
01/06/09 02:18 PM
01/06/09 02:18 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I simply went for the modest one of all, and fit down the ashtray area under the dash frame. Closer look to originals. I didn't want some fancy, and more in fact disimulated
EVEN USED ONE OF THOSE BLUE LIGHT RUBBER BULB LENSES what I had extra to get same color than rest of cluster lights, instead the ones provided.
2892 tach
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184884
01/06/09 02:39 PM
01/06/09 02:39 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
I usually use Auto-Meter or Auto-Gauge.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184885
01/06/09 03:04 PM
01/06/09 03:04 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Those aren't actually Monster tachs, but if that is what you want to use, that is your choice. Personally, I prefer the white face gauges, but the one I have is a black face. Like I said before, it was free. This is what I have: http://store.summitracing.com/partdetail...mp;autoview=sku
Really, you can't go wrong with any Autometer or AutoGage gauge. Just pick the one you like best and run with it.
Re: Looking for a Tach: Need advice! [Re: dodgeram440] #184886
01/06/09 04:16 PM
01/06/09 04:16 PM
United States
United States
AHH, my mistake in the description. You are right, they are not the monster tach.
Thanks again for the advice!
Re: Looking for a Tach: Need advice! [Re: STLDuster] #184887
01/06/09 06:19 PM
01/06/09 06:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run a 2 7/8" tach on the steering column, on the nub where the column shifter used to be. It's decent, not too big, not too small. But I'm scrapping it and going to an in-dash 3 3/4" autometer instead.
