1970 Plymouth gtx pig tail ends #1848667
06/14/15 01:17 PM
06/14/15 01:17 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi i need to repair a pig tail end on the wire harness for the hood lamps were can i get the female end in black thank you fury
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: 1970 Plymouth gtx pig tail ends [Re: GTXKARL] #1848731
06/14/15 01:57 PM
06/14/15 01:57 PM
classic industries MIGHT have something
Re: 1970 Plymouth gtx pig tail ends [Re: RapidRobert] #1848860
06/14/15 04:57 PM
06/14/15 04:57 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
thank you for the help .they have the wrong ones. i need the round ones
Re: 1970 Plymouth gtx pig tail ends [Re: GTXKARL] #1848880
06/14/15 06:09 PM
06/14/15 06:09 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Post a pic of what you need.
Re: 1970 Plymouth gtx pig tail ends [Re: Pynzo] #1849012
06/14/15 08:46 PM
06/14/15 08:46 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
I hope this works.
Re: 1970 Plymouth gtx pig tail ends [Re: GTXKARL] #1849364
06/15/15 02:59 AM
06/15/15 02:59 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I think those are the same as 68/69 Charger hood turn signal wiring? I know those wiring kit components are available separately.
68 Charger R/T 440 auto
Re: 1970 Plymouth gtx pig tail ends [Re: wesgtx440] #1849433
06/15/15 10:26 AM
06/15/15 10:26 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Those are used on several models in several different applications. up I used to keep a couple around for the ignition switch in a derby car... whistling They shouldn't be hard to find used if you don't mind splicing it in... twocents
...FAFO...
