Re: Rocker arm side clearance?
[Re: gss]
#1848522
06/14/15 03:23 AM
06/14/15 03:23 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Call Comp on Monday morning and ask them Let us know what you find out.
[Re: gss]
#1848572
06/14/15 10:43 AM
06/14/15 10:43 AM
crabman173
crabman173
Comp will not be anything but a waste of time--that is fine and will run great with zero issues--.017 would be perfect IMO work on the pairs by just moving hold downs etc to get what you need--if you loosen the bolt the hold downs will move left and right some--split it to get where you need to be
[Re: gss]
#1848691
06/14/15 01:32 PM
06/14/15 01:32 PM
Thumperdart
State of confusion
Been running mine between .010-.012 w/no issues.........
[Re: gss]
#1848857
06/14/15 04:47 PM
06/14/15 04:47 PM
crabman173
crabman173
That is fine if that is what they say--won't hurt a thing--wider makes noise but no harm Too tight and then ya got trouble No way to set up a Mop with adjustables of any brand w/o working it over, grinding shimming etc If you are not "cheating" the roller to valve tip to get room for the pushrod by the port you just plain have it too easy
[Re: gss]
#1848858
06/14/15 04:47 PM
06/14/15 04:47 PM
crabman173
crabman173
