MP chrome box vs. orange box #1848350
06/13/15 10:27 PM
06/13/15 10:27 PM
USA
JoesMopar Offline OP
USA
So other than the higher rpm range in the chrome box, is there any performance difference using the chrome box over the orange box at the same engine speeds achieved by both?
Re: MP chrome box vs. orange box [Re: JoesMopar] #1848352
06/13/15 10:33 PM
06/13/15 10:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Chrome box has a better history.
Re: MP chrome box vs. orange box [Re: stumpy] #1848483
06/14/15 01:23 AM
06/14/15 01:23 AM
Listen to Stump. it can miss it can pull timing it can fail. it may last for years. YMMV! Do ya feel lucky, well do ya. EDIT I believe the chrome can handle a higher pri current load over time before failing
Re: MP chrome box vs. orange box [Re: RapidRobert] #1848530
06/14/15 03:49 AM
06/14/15 03:49 AM
USA
USA
So other than less incidence of failure and spark at higher RPM, there really is no performance benefit...is that right?
Re: MP chrome box vs. orange box [Re: JoesMopar] #1848534
06/14/15 04:15 AM
06/14/15 04:15 AM
Actually there are reports of "pulled timing". The ECU is supposed to open the circuit from the coil neg primary post right when the signal from the pickup tells it to. for instance at 3k if the pickup triggers at IE 45 deg BTDC (initial+slots+can) & the box is acting uP & delays opening the above circuit until say the crank is at 40 BTDC then the ECU has pulled 5 deg out of it by not doing its job. I ain't sayin the orange box will or it wont but between those reports (few cuz most people dont plot a curve then sub in another box & see if the curve is the same) but between that & the multitude of reported failure I would not purchase one exp since there are alot better ways to go (even if you wanna keep it OE with a Mopar ECU for easy parts availablity
Re: MP chrome box vs. orange box [Re: JoesMopar] #1848543
06/14/15 07:10 AM
06/14/15 07:10 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I have heard that the Hi-Rev ECU is a reliable alternative to the Orange box. It is not a Mopar made unit, but it has the same (or very similar) RPM range. Price is nice too.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: MP chrome box vs. orange box [Re: JoesMopar] #1848711
06/14/15 01:47 PM
06/14/15 01:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have an orange box I bought around 1999 and it is still going strong on my 63. We took it off my sons Dart when we put MSD on his Dart. His Dart ran no different and was no faster with the MSD so I took the orange MP ECU and used it on my 63. I have checked it for high rpm timing retard and have not seen any and its on my 63 now running 10.70's and never missing a beat. I hear all kind of horror stories about the ones bought in the last 5 to 10 years but some still get good servive with them. So if you buy one now it could be hit or miss from what I hear but as I say I have had good luck with them. They used to say not to use the chrome box on a street car that will idle any longer then 30 minutes as the chrome was to be more for racing I believe. But many use it on street cars with good luck.
The funny thing is that at real high rpm's you can actually make more power pulling some timing back out but thats not what the orange box is supossed to do. I would say that which ever you use just carry a spare as I do but I have never used it. There are many guys out there still using the MP ECU's but there are also many other ign setups out there as many just use the good old MSD which is a great ign. Myself I plan to change to the MSD one day just because I like the lower rpm multi-spark it gives as its nice in helping kep plugs clean and the MSD is a very good all around ign. Ron
Re: MP chrome box vs. orange box [Re: stumpy] #1848746
06/14/15 02:24 PM
06/14/15 02:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But,for what it's worth if you do a little research you will find the chrome box was designed as a race unit good for 8,000 rpm,and not recommended for street use. work
Re: MP chrome box vs. orange box [Re: 383man] #1848790
06/14/15 03:07 PM
06/14/15 03:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i think alot of the orange box failures are the result of folks NOT using a ballast resistor with street use.
Re: MP chrome box vs. orange box [Re: JoesMopar] #1848873
06/14/15 05:46 PM
06/14/15 05:46 PM
P
Paul_Fancsali Offline
P
I said this often the stock factory boxes are just as good I own chrome and orange and both have failed or caused problem MSD forget it another piece of crap for a street car Do they work yes do they fail under constant use or heat YES, Use them on race cars not on something that you are on power tour with if you insist on it carry a spare you will need it sooner then later. The Mopar boxes are just not that reliable esp off shore produced When I had a fleet of Dodge vans during the 80s My rule was if pickup coil failed change the box or vice versa and never had a issue again this was only a rare problem
Re: MP chrome box vs. orange box [Re: mikemee1331] #1848879
06/14/15 06:08 PM
06/14/15 06:08 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have used the Orange and the Chrome box on my '64 Polara with a mild 440. When I sold it to a man in Chicago it had the Chrome box mounted on a stand off mount I made on the pass side of the radiator core support. I had some left over Orange boxes and gave them away to people in the club as I had a Cummins daily driver then.
I started the Ramcharger project and decided I wanted a CD box with a rev limiter built in. I looked at the MSDs and settled on the Mallory version that uses a rotary dial to set the limits. Then I needed to upgrade my '87 D100 from the Lean Burn ($%#@) system it had, so I used it there with a rebuilt '74 Challenger distributor (it had a vacuum advance, the '87 dist did not) to trigger it, with a new Accel coil. Serious overkill, but so far, so good.
On the racer I am going to use the conversion kit that puts a GM HEI 4 pin module on the bottom of the 440 dist and a 50,000 volt E-Coil.
All of these options are better than the Chrysler boxes IMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: MP chrome box vs. orange box [Re: Polarapete] #1849398
06/15/15 07:59 AM
06/15/15 07:59 AM
Ohio
dobie Offline
dobie  Offline
Ohio
As always, Im in the minority here. I have both the orange and chrome box. The orange box came with my kit years ago back in 2006 or 2007. After converting my RR over, I used that box for quite awhile. Hanging around here I kept reading how poor the orange boxes were and that I should get a chrome box to solve all the world's issues. Well, that chrome box was horrible. The minute I put that thing on my car, it ran for crap. It wouldn't idle at all as the rpm's would swing like a fourth grader at recess. Trying to drive the thing was even worse. It would surge to the point of almost killing the motor to darn near wide open throttle at take off. Id put the orange box back on, and all was well.
I tried this three times to make sure I wasn't doing something wrong on the install. Three times I had the same results....That chrome box was/is unusable with my car. I have no idea why either of course.
A couple of years ago I bought one of the new Rev-n-ator boxes at Carlisle. So far I haven't had any issues. I didn't experience any of the claimed hp or mileage increases, but the car runs just fine with it installed. For now, I have the Rev-n-ator installed if for nothing else because of the built in limiter. My original orange box now lives in the trunk as a spare.
1968 Plymouth Road Runner 383 4 speed
Re: MP chrome box vs. orange box [Re: dobie] #1849413
06/15/15 09:42 AM
06/15/15 09:42 AM
As I have no idea why either of course.
You're fine bro, actually you just had a bad/defective box that happened to be a chrome one
Re: MP chrome box vs. orange box [Re: RapidRobert] #1849587
06/15/15 02:04 PM
06/15/15 02:04 PM
dogdays Offline
dogdays  Offline
Chrome box has a better history? BS. It's so funny reading all this "X" box vs "Y" box and then someone chimes in that MSDs are pieces of crap, etc etc etc.
IF you go back 10-12 years the box that was giving the problems was the chrome box. I remember plenty of posts about chrome boxes that barely made it around the block before failing. At that point the orange box was supposedly "better" than the chrome because it didn't fail nearly as often. The chrome box also supposedly pulled timing at high rpm. "Crap", they called it.
Now the chrome box has miraculously made a comeback as the better box, and it's the orange box that barely makes it around the block before failing, and pulls timing.
The ballast resistor question is also specious. I bet there are more guys trying to run a CD box WITH the ballast resistor, than those running an orange or chrome box WITHOUT the ballast resistor. More paper excuses.
I ran an orange box for years, bought it in 1984. In around 1997 or so I thought something was wrong with my orange box. I bought a $40 used MSD6 on Ebay and installed it, being careful to wire it according to the MSD instructions that are everywhere on the Net. I used the Jacobs coil I had used since 1984, also wired the way MSD said to do. It's still running. My only problem has been oxidation in the pickup coil wiring plug.
About 1998 or so the ignition in my '93 Suburban went south so I replaced the distributor with an Accel Billetech and the ignition with an Accel 300+ that I bought brand new for around $110. It has lasted around 130,000 miles bolted to the firewall in an engine compartment that runs so hot you cannot hold your hand against the hood after a hundred miles.
If one has to have a box that uses the Chrysler Electronic Ignition wiring, I'd skip the MP boxes, also any foreign made replacement ignition box, and go straight to either the RevNnator or else FBO's box. I like the looks of the FBO box because he is using a Daytona Sensors circuit board and they're a pretty good company.
Regarding the pulling timing issue, yes years ago it was discovered that cars would ET better if some timing was pulled at high rpm, don't ask me why. But reading the Webpage of the dude who rebuilds and upgrades analog MSD boxes, I seem to recall that he replaces slow transistors with faster ones. I wouldn't be at all surprised to learn that the transistor used as a switch in the MP boxes is one of the slower ones.
To summarize: I am happy with my aftermarket multispark CD ignitions and will leave my Chrysler factory stuff on the shelf. Maybe someday some restorer will want to pay big bucks for it.
R.
Re: MP chrome box vs. orange box [Re: JoesMopar] #1849651
06/15/15 03:04 PM
06/15/15 03:04 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
In twenty years of driving...
And thousands of miles...
In all types of conditions...
(Bumper to bumper 90 degree+ heat;sustained high-speed runnin';the drag strip...)
I've lost exactly one orange ECU...
Re: MP chrome box vs. orange box [Re: JoesMopar] #1849739
06/15/15 05:16 PM
06/15/15 05:16 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Interesting indeed.
Thanks guys.
Re: MP chrome box vs. orange box [Re: RSNOMO] #1849785
06/15/15 06:50 PM
06/15/15 06:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And to problem orange box started in the 90's with a vendor change,never had an earlier 90's or older one fail.
Re: MP chrome box vs. orange box [Re: 62maxwgn] #1849795
06/15/15 07:07 PM
06/15/15 07:07 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
When I purchased my car it had a chrome box on it..no issues...I later switched to a orange box and there is no difference what so ever on this street car...My 72 440 RR has a 5 prong block...My old 72 400 had a 4 prong block and I can find nobody than knows the difference and why ??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: MP chrome box vs. orange box [Re: JoesMopar] #1849801
06/15/15 07:12 PM
06/15/15 07:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The funny thing is I started with muscle cars and drag racing around 1974 and was using and Acell dual pont dist in my 340 Dart up until I rolled it in 1982. It ran a best of 11.90's and after that I stared using the MP ign box's. And to this day I have never had a Mopar ign ECU box or a ballast resister fail on me. I always carry spares but have never used them. Ron
Re: MP chrome box vs. orange box [Re: 72N96RR] #1850238
06/16/15 04:17 AM
06/16/15 04:17 AM
The original early (72 ish) electronic setups used a 5 pin ECU with a 4 terminal (dual) ballast. later kit (orange/chrome/gold ECU's had the start circuit combined inside the ECU & no longer needed the extra ~5 ohm half of the "dual" ballast. Aftermarket ECU's are avail in 4 or 5 pin & the 5th pin is a dummy (has no continuity) & was introduced cuz people making parts purchases were complaining that it was the wrong one (comebacks before they even installed it which if they did install it they woulda found that it worked) cuz a 4 terminal (dual) ballast system will work with a 4 or a 5 pin ECU but the parts mfrs just added a fifth pin to stop the complaints/comebacks. An OE 5 pinner ECU with a functioning 5th pin (has some resistance in the red/green wire pin) does require a 4 terminal "dual" ballast. Not sure if this is what you are after but I've been gone all day & I miss my computer time
