wiring sun tach #1847618
06/12/15 08:12 PM
06/12/15 08:12 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
Put a small Sun tach in my rally dash (70 Dart)There are 4 wires, red ( hot) I ran to the main dash power (red) black to the main ground, green tru the bulkhead connector to the coil and white to the input for the instrument lights. Tach doesn't work and light stays on always. Any hints on what is wrong?
Re: wiring sun tach [Re: 70dart318] #1847633
06/12/15 08:20 PM
06/12/15 08:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do you have electronic ignition?
Re: wiring sun tach [Re: 70dart318] #1847705
06/12/15 10:08 PM
06/12/15 10:08 PM
Streetsboro,Ohio
Streetsboro,Ohio
yes, Mopar performance.
Re: wiring sun tach [Re: 70dart318] #1847713
06/12/15 10:19 PM
06/12/15 10:19 PM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
green wire on the positive side of the coil?
Re: wiring sun tach [Re: 70dart318] #1847717
06/12/15 10:29 PM
06/12/15 10:29 PM
Streetsboro,Ohio
Streetsboro,Ohio
Yes,positive side.
Re: wiring sun tach [Re: 70dart318] #1847721
06/12/15 10:35 PM
06/12/15 10:35 PM
put it (green wire) on the neg pri coil terminal
Re: wiring sun tach [Re: 70dart318] #1847797
06/13/15 12:02 AM
06/13/15 12:02 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My Sun wouldn't work with that, older ones where made for points, got a transmitter box from MSD to make work if I remember right.
Re: wiring sun tach [Re: cudaman1969] #1847963
06/13/15 11:01 AM
06/13/15 11:01 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
You didn't mention what model/number tach you have but Cudaman 1969 is correct. If the tach is an older model, it needs a tach adapter.
Re: wiring sun tach [Re: 70dart318] #1848034
06/13/15 01:10 PM
06/13/15 01:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pick up (green wire) belongs on the negative side of the coil. You are feeding it 12v constant voltage and that is why it's staying lit and not reading.
Re: wiring sun tach [Re: stumpy] #1848043
06/13/15 01:24 PM
06/13/15 01:24 PM
you'd think that the coil neg post (circuit) would be getting opened/closed (to ground) the same whether it points or ECU doing the job but yeah swap the wire & if that dont do it then spring for the adapter
Re: wiring sun tach [Re: 70dart318] #1848118
06/13/15 03:09 PM
06/13/15 03:09 PM
Streetsboro,Ohio
Streetsboro,Ohio
It is a newer model, bought a few year back. I found the booklet for my other Sun Super tach and it says run it to a positive that only gets power when ignition is on, and to engine or chassis ground, so having it run to the dash may be the problem. It was on the negative side before and didn't work there either.
If anyone can remember where you ran tour wires ( e.g red to fuse block accessories terminal)please post, it would be helpful.
Re: wiring sun tach [Re: 70dart318] #1848129
06/13/15 03:23 PM
06/13/15 03:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wire the red to something like the radio fuse that is only hot with the ignition on. You may have fried the tach by having it hooked up to the coil positive.
Re: wiring sun tach [Re: 70dart318] #1848525
06/14/15 03:34 AM
06/14/15 03:34 AM
I'd T into the heaviest switched 12V wire (hot only when key is on) such as the heater that you can see in the fuse box & tap into (T) before the fuse (such as heater) on the back side & then solder a wire out from the T then run it on to the tack red wire. This keeps the heater porotected with the 20A fuse with no extra draw on that circuit & you are protecting the tack with an inline seperate fuse (ask Sun what they want/maybe 5A)
Re: wiring sun tach [Re: RapidRobert] #1848562
06/14/15 10:02 AM
06/14/15 10:02 AM
moparx Offline
moparx  Offline
mostly, its : red - 12v key on
green - coil neg. [-]
black - ground
white - lights [usually tied into orange dash lite
circuit harness]
beer
Re: wiring sun tach [Re: 70dart318] #1849193
06/14/15 11:35 PM
06/14/15 11:35 PM
Streetsboro ,Ohio
72duster318 Offline
72duster318  Offline
Streetsboro ,Ohio
We wired another Sun into the Duster,to see what would work,red to fuse block,black to dash frame,green thru firewall to coil,works like a charm. Will play with the white later. I got thee yach in the Dart unwired and I am going to wire it same as the Duster later this week. Thanks again for all your help everyone.
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
