Page 1 of 3 1 2 3
highest hp street small blocks on here?? #184762
01/05/09 05:59 PM
01/05/09 05:59 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Tell some combos here for your street small blocks. I have a 340 and 360 block. Trying to decide whether to build a stroker engine or spend the money on a basic 340/360 combo with a healthy cam and decent compression. It'll be going into an a body. Thanks
Re: highest hp street small blocks on here?? [Re: DusterKrazy] #184763
01/05/09 06:51 PM
01/05/09 06:51 PM
ERIE PA home of the RENCH MOB
mike_vango Offline
mike_vango  Offline
400hp. 9.0:1 stock bore and stroke 360. 1.925/1.625 iron heads. .501/.513 288-292 roller. 750 holley. stock ignition. 3.55s
74 swinger granny edition. 12s on whitewalls
^^i had my brothers 440 belvedere smoked before i shifted^^^
Re: highest hp street small blocks on here?? [Re: mike_vango] #184764
01/05/09 06:58 PM
01/05/09 06:58 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Go with a .040 360 and a get 500 hp. Makes a 410 with the stroker crank.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: highest hp street small blocks on here?? [Re: DusterKrazy] #184765
01/05/09 07:56 PM
01/05/09 07:56 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Mine is not the fastest out there, but it is a nice street friendly combo that has been running for thousands of miles and never overheats.
340 .30 over, stock stroke with original forged crank. Stock rods, forged factory style replacement TRW pistons with 10.1 compression. Comp XE274 hydraulic cam, unported X heads, Edelbrock Air Gap intake, 650 Holley DP. 3.91 gears, PTC 3,500 converter, 28" tall drag radials. Car weighs 3,500 pounds with me in it.
Est. 400 HP at the flywheel based on quarter mile time of 12.91 @ 103.7. No nitrous, aluminum heads, or stroker needed. Still need to play with the timing too. Driven to and from the track, runs consistent within a couple thousandth so it makes a good bracket car to boot.
Re: highest hp street small blocks on here?? [Re: dustergirl340] #184766
01/05/09 08:01 PM
01/05/09 08:01 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
build the stroker so you dont do it twice
Re: highest hp street small blocks on here?? [Re: fasthawk6] #184767
01/05/09 08:07 PM
01/05/09 08:07 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
73 340 Duster
Has 10.6 to 1 360 with ootb edelbrock heads, , edelbrock air gap, holley 750 dp, hughes HE3038 cam (231/237 duration),MP distributor with chrome box, tti stepped headers, 727 with stock converter and 3.23 gears, cooper II 225/60 x 14 tires.
spinning tires....14.01 @ 101.26 in Vegas.
Tony
70 AARCuda Vitamin C
Re: highest hp street small blocks on here?? [Re: 70AARcuda] #184768
01/05/09 10:09 PM
01/05/09 10:09 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Not sure what mine makes, probably about 350-375hp, but its a VERY simple engine combo.
'77 360 with stock pistons
Magnum Heads with R/T Springs & Retainers
Summit K6901 camshaft (218/228 with .441/.441 lift (.470/.470 with the 1.6 rockers)
1 5/8" headers
Edelbrock Air Gap intake (Magnum type)
600 Holley.
This thing runs strong!!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: highest hp street small blocks on here?? [Re: goldduster318] #184769
01/05/09 10:38 PM
01/05/09 10:38 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
467 horsepower and 510 foot pounds, 408 stroker eddie aluminum heads. Not even close to the highest, but makes me happy.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: highest hp street small blocks on here?? [Re: FurryStump] #184770
01/06/09 09:30 AM
01/06/09 09:30 AM
Outside
thedriver Offline
thedriver  Offline
Outside
not the highest, but runs good, for a street car
340ci 10.5 cr, eddie heads, 750 demon, air gap and a XE285HL cam from comp, 3500lb car with me in it, 727, 3.9 gear,,, best is listed in my sig.
1973 challenger
Dana. 4 speed. Low deck.
Re: highest hp street small blocks on here?? [Re: thedriver] #184771
01/06/09 09:36 AM
01/06/09 09:36 AM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
highest..not, but will put a smile on your face!410 Stroker 9:7 cr,500hp/500trq,eddie heads, RPM airgap intake, 850 proform,tti headers (RyanJ motor) lots of fun with a stick and 3:91 gears.. and do it all under 6,000 rpm. Very streetable (love giving chebby friends a ride)
Re: highest hp street small blocks on here?? [Re: thedriver] #184772
01/06/09 02:15 PM
01/06/09 02:15 PM
mike_vango Offline
mike_vango  Offline
your car/combo sounds great!
Re: highest hp street small blocks on here?? [Re: mike_vango] #184773
01/06/09 03:55 PM
01/06/09 03:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Not highest but..
+.030 360, stock crank and rods
speedpro flat tops at zero deck
home ported j's, 2.02
torker II, 750 Dp
Comp solid 520/540 .244/.252 @ .050
Demon with a auto and 3.91 26" tall slicks
12.22 at 109.5 mph, 1.66 60' First and only time at track, was to rich & didn't even play with timing !
so simple and cheap its not even funny!
Re: highest hp street small blocks on here?? [Re: DusterKrazy] #184774
01/06/09 04:00 PM
01/06/09 04:00 PM
dusterjp Offline
dusterjp  Offline
Last winter I pulled out a .30 over 9 to 1 340 with stock X heads, 292/509 cam and an RPM Air Gap intake with a holly 750 carb and TTI headers. I built a .40 over 418 ci stoker motor with h beam rods and diamond pistons (10.9 to 1 compresion). I also had a set of edelbrock heads ported and I pretty much used the rest of the parts I already had. The motor makes about 525 horse power. It is in a 70 Duster with a 4spd. and a 3.91 gear. The only thing I can tell you is the first time I got into it, after it had a few miles on it of course, I almost had to go home and change. It was worth every penny.
Re: highest hp street small blocks on here?? [Re: dusterjp] #184775
01/06/09 08:00 PM
01/06/09 08:00 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
360 block, 408 stroker. forged Ross pistons (10.2:1), Eagle cast crank, H beam rods, .600 lift, scorpion rockers, Isky springs (can't remember rate), Scott Brown custom ground hydraulic cam (248/254@.50) Ported Eddy heads flow 284 cfm (gasket matched), stock M1 intake, Proform carb... flows like an 850. TTI headers. 480 horsepower, 500 ft. lbs. tq.
With a 3.91 rear and a 4 speed, it's all you need on street tires... I spin through 3rd gear. If I were building from scratch, I'd only change the carb and MAYBE up the compression to 10.5-10.7 or so. Buy a Demon. My money is far better spent on tires at this point though if I were looking for the best e.t. and since I don't race, I don't need slicks or drag radials, so basically I am where I need to be: HAPPY!
Re: highest hp street small blocks on here?? [Re: DusterKrazy] #184776
01/06/09 08:45 PM
01/06/09 08:45 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Heres mine.
1971 360 block
Eddy heads ported by Hughes milled to 57cc chambers
Flat top KB. pistons 11.7-1 comp runs fine on 93 octane
Smith brothers pushrods
Comp cams custom grind- .544 intake/.576 exhaust with 1.6 rockers, duration at .050 242/254
Stock crank and rods
M1 single plane intake with super sucker spacer
950hp holley carb
msd ignition 6al with a billet dist.
Dynamic 9 1/2 converter 727 trans
4.10 gears
Best et. = 11.24 @ 121
421 hp at the wheels.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: highest hp street small blocks on here?? [Re: Cudahlr] #184777
01/07/09 01:00 PM
01/07/09 01:00 PM
New Brunswick, Canada
CoyoteJack Offline
CoyoteJack  Offline
I guess I'll jump in here to.
+.040 360
KB flat tops
Magnum heads (worked on with 2.02 valves)
M1 dual plane
Comp Cams Magnum 280H total lift .512
Crane roller rockers
MSD 6AL and billit dizzy
650 Speed Demon
1 inch spacer
1 5/8" tubes to 3" outlet Dynomax headers
2800 stall tc
727 reverse manual valve body
4:10 8 3/4
SS springs
M/T sportsman pros
This engine combo dynoed 392HP/412 TQ with a Comp Cams 268H and before I installed the roller rockers. I don't know if the spacer and Speed Demon gained me anything or not but the seat of the pants dyno tells me they did. I estimate my Hp to be in the 425 range now.
Jack
Re: highest hp street small blocks on here?? [Re: CoyoteJack] #184778
01/07/09 04:30 PM
01/07/09 04:30 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
Ok here is my combo:
+0.035 over 340
4" Eagle forged crank
reconditioned stock rods
custom forged Venolia pistons
9.5:1 compression
stock 340 'X' heads completely gone thru (no porting)
Mopar Performance 484 Purple Cam (241/241, .484/.484 lift 108 lsa)
new stock stamped rockers
Edelbrock RPM airgap mainfold (dual plane)
Holley 770 Street Avenger carb (it has been re-jetted)
FBO ignition system
TTI headers and TTI 3" exhaust system with Flowmaster 40 mufflers
3.91 gears
4-speed
70 Cuda
The car dyno'd at 375 peak RWHP when the clutch started to slip at 5000rpm (so there is still more HP in there) and 484 peak RWTQ. Figuring a 10% loss for the drive train this puts the HP at about 420 at the crank (when the clutch started to slip) and 537 TQ at the crank.
Future plans for the motor:
-Ported Eddy heads
-10.5:1 (or higher) compression
-Roller hydralic cam and rockers (the cam will have a little bit more duration and more lift then the current cam)
-850 Holley DP Carb
With these upgrades I hope to make around 500HP/500TQ at the crank. Looking at what other people have posted with their combos this should be possible.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: highest hp street small blocks on here?? [Re: loco340cuda] #184779
01/07/09 10:13 PM
01/07/09 10:13 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's the one I plan to bracket race....Quick77R/T built the shortblock
360+.030 roller block
11:1
Eddie closed chamber Heads...bowl blend, Good VJ and open the pushrod pinch to .980 (per RyanJ's recommendation)
Hydraulic Roller 236/240@.050 ..554/.540 lift 112 centers, 107ICL
1.6I 1.5E rockers
Performer RPM...minor porting
830 annular Holley
1 3/4 headers
904 Lock-up w/Shift kit
3200 stall 10" converter
* 3/4" b body rear, 4.10 gear
28" x 10.5" slick
Should be similar to a few others here like Ademon's. A basic, reliable, powerful, nice combo.
Looking to go consistent 7.50's in the 1/8th in a 1992 Daihatsu Rocky that weighs ~2950 lbs w/me in it. 87" wheelbase so that's why I spread the lobe centers and oversized the carb to kill a off idle and little midrange (shiftpoint) torque to make it more tractible until I get a handle on how to make it go rounds. I may go to a single plane if it still has too much torque off the line or a Vac secondary if it goes a little too quick. I figure it should make ~425 (well probably a good bit more )by ~6000rpm pretty easily.
WIZE
In Car:
Re: highest hp street small blocks on here?? [Re: Streetwize] #184780
01/07/09 10:30 PM
01/07/09 10:30 PM
Leetonia, OH
R6T8net Offline
R6T8net  Offline
Leetonia, OH
416 stroker
Forged crank, H beams
10.1:1
Full roller
Ported eddy's
Airgap
850 Mighty Demon
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
Re: highest hp street small blocks on here?? [Re: R6T8net] #184781
01/07/09 10:49 PM
01/07/09 10:49 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
416" Shady Dell ported W-2's, 272 @ .050 .610 lift Racer Brown, 17/8" TTI's, PF 950HP, TA 4400 convertor, 4.30 gear, ported Indy intake, 3500 lb. A body. 11.08 @ 120 mph
Page 1 of 3 1 2 3
