BRAKE BLEEDING PROBLEM (FRONT LINES) ON 70 AAR CUDA
#1847353
06/12/15 01:47 PM
06/12/15 01:47 PM
Posts: 1,551 Sweden
71redcuda
Sweden
Hello everyone..
Need some help here, im no expert on this.
I have restored the original master brake cylinder and now when im need to bleed the front brake lines its not going my way.. the master brake cylinder has been bench bleed and reinstalled on car, the problem is that no brake fluid runs thru the front lines down to the calipers..
Has this something to do with the proportion valves under the master cylinder or??
Any help is appreciated.
Thanks Nicklas
Re: BRAKE BLEEDING PROBLEM (FRONT LINES) ON 70 AAR CUDA
[Re: 71redcuda]
#1847613
06/12/15 08:06 PM
06/12/15 08:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The brake fluid to the front brake lines does NOT go thru this valve.. Maby need to change it out... Reset the Proportioning valve by pulling the pin outward on that valve body to open the ports
[Re: DAYCLONA]
#1847630
06/12/15 08:18 PM
06/12/15 08:18 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
The brake fluid to the front brake lines does NOT go thru this valve.. Maby need to change it out... Reset the Proportioning valve by pulling the pin outward on that valve body to open the ports This problem seems to come up every month on here...Was'nt there a factory procedure involving a clip that got installed on that pin while the brakes were bled ??? I can't find the pic of it in my files....
