who makes replacement steering shaft coupler?
#1537929
11/21/13 08:01 PM
11/21/13 08:01 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i have an 88 150 ram 4x4 purchased it for my son.. I need to replace the steering shaft coupler/universal joint. its sloppy..not the rubber disk...the actual joint the attaches to the steering box. who makes a new one? also does anyone know what range of yrs the part is the same...as an 88 model.?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: who makes replacement steering shaft coupler?
[Re: 440newport]
#1537931
11/21/13 10:06 PM
11/21/13 10:06 PM
cheapstreetdustr
i had a rebuild internal guts kit...i installed it a few yrs back on this truck for the owner....it arleady sloppy again..(actually its been about 5 yrs..but he had a gravel potholed driveway.. im ..thinking its the cast piece worn out.. i may do the borgenson deal...and be done with it.
[Re: 500ciDuster]
#1537938
11/22/13 10:30 PM
11/22/13 10:30 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Do a search over at RCC for an article about building your own "Borgeson" shaft from a couple of pieces from pull-a-part. Did something similar for a Samurai I built a while back and it worked great. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
